DIY Solar: 6 Reasons Not To Do It
RSSfeed
Registered Users Posts: 3,810 ✭✭
The growth of solar power is continuing its trend upwards and so is the amount of promoted DIY solar panel kits out on web. DIY solar panel kits may seem like the ideal solution as you may initially think it’s going to help cut down on cost; however, this isn’t necessarily the case. *Professional solar [...]The post DIY Solar: 6 Reasons Not To Do It appeared first on Solar Feeds.
go to solarfeeds for the rest of this story>>>>>
More...
More...
Re: DIY Solar: 6 Reasons Not To Do It
Seems to confuse "why you shouldn't do a DIY install", with "why you should build your own panels"......as if the two are the same thing, which they clearly are not. -
I toyed with deleting this "news" or sticking a disclaimer on it but figured most everyone here could see how badly written it was and get a good laugh at least.
