Inline 80A fuse on 2AWG wire?
porch13
Registered Users Posts: 68 ✭✭✭
I just purchased a Xantrex Prowatt 600w inverter for my little place in the woods. My cables from the batteries are 2AWG. I need to add an 80 amp fuse, per the manufacturer, but I'm not sure what type will fit on 2 gauge wire. Can anyone point me at one that will work at a reasonable price?
Thank you!
Kyocera 210 watt panel, SunSaver SSMPPT-15L MPPT Charge Controller, 2 6V 220AH Batteries, Xantrex Prowatt 600w Inverter
Thank you!
Northern Arizona...4050 Watt off-grid system - Outback FP1 - Rolls 605 in a 48V bank
Re: Inline 80A fuse on 2AWG wire?
Can you define "reasonable price"?
Were it me, I'd use one of these: http://www.solar-electric.com/mr60ampdccib.html
Circuit protection and disconnect in one.
Or you could put a Blue Sea battery post fuse in:
http://bluesea.com/products/category/Terminal%20Fuse%20Blocks
http://bluesea.com/products/category/Marine%20Rated%20Battery%20Fuses -
This would also be my recomendation if Iwas going to use a fuse..Were it me, I'd use one of these: http://www.solar-electric.com/mr60ampdccib.html -
I love the circuit breaker idea. Thanks much for the input guys!Northern Arizona...4050 Watt off-grid system - Outback FP1 - Rolls 605 in a 48V bank
- 231 Forum & Website
