Looking for a a basic formula
Hairfarm
Hairfarm Solar Expert Posts: 225 ✭✭✭
Greetings,
What is the basic formula that will allow me to convert AC watts into DC amps?
In other words, if a load can potentially draw 2000 watts max from my inverter, then how many DC amps is the inverter pulling from my battery bank?
What is the formula for that?
I couldn't find this anywhere in my notes that I've taken from this forum over the last few days.
thanks,
    BB. Super Moderators, Administrators Posts: 33,744 admin
    Re: Looking for a a basic formula
    Here is what I do... I will use "real numbers"--Just substitute your values:
    • 2,000 Watt * 1/0.85 Inverter eff * 1/10.5 volt batt cutoff * 1.25 NEC Derating = 280 Amp circuit/fuse/breaker minimum
    If you just want the amps at any typical value:
    • Power = Watts = Volts * Amps
    • Amps = Watts / DC Volts
    But, of course, inverters have losses (around 85% is a good number), the inverter will draw more than its loads:
    • Amps = Watts * 1/eff * 1/DC Volts
    • 2,000 watts * 1/0.85 inverter eff * 1/12.2 volts = 193 amps at nominal battery voltage and inverter efficiency
