Peel-and-stick solar panels: Decal-like application process allows thin, flexible solar
RSSfeed
Registered Users Posts: 3,810 ✭✭
Decal-like application process allows thin, flexible solar panels to be applied to virtually any surface from business cards to roofs to window panes. Process is the first to use existing processes and materials pointing to potential commercial viability.
More...
More...
Re: Peel-and-stick solar panels: Decal-like application process allows thin, flexible so
But, do we actually need stick-on solar? -
you wanted shade from that existing window,no? problem found for the solution..
- 225 Forum & Website
- 617 Discussion Forums/Café
