Panel Mixing, please comment on my proposal.
machineman
Solar Expert Posts: 129 ✭✭✭
I need to add more capacity to my off grid system. (24V, 440ah batterys, CC XW60-150 mppt)
Existing 4 panels in series total: Vmp 72.8v, Imp 11.27 (total 820w)
Proposed 2nd string of 4 panels in series total: Vmp 70.16, Imp 11.53 (total 809w)
So with adding the 2nd proposed string in parrallel with the existing string:
Total combined current will be 22.8amp travelling from my roof 90ft to CC on 8ga. I calculate the Voltage drop <5%. - GOOD
Also I calculate I will boost my chargeing capability from 6% to 13% of the battery capacity (using 28.8v in the calc) - GOOD
My XW CC can handle 60amp and up to 150V. I calculate 56.6amps max (without factoring efficiency loss) - GOOD
So I will have a 2.64Vmp difference between the parrallel strings which will be combined on the roof. Is this OK? - ??
Thanks.
Thanks.
Off Grid Cabin, 24V 440ah 6V GC battery bank, Xantrex MPPT60-150 CC, Magnum MS4024 inverter-charger, >1200w Solar bank
Re: Panel Mixing, please comment on my proposal.
From what I can see--Should work fine... The ~2.64 volts out of ~70 volts is not going to be a problem.
A Vmp difference of 2.64 on ~70 Volt strings is very small: roughly 3%. It won't be noticed.
If the 5% V-drop is acceptable to you, okay.
Your array total will be 1629 Watts, and probably produce a maximum current of 52 Amps to the batteries. That's just under 12% for the 440 Amp hours.
Looks workable to me. -
Ok thanks. This is good news, its been tough to find panels close to my odd ball Evergreen ES-A string Vmp. So I don't need any diodes or anything between the strings?Off Grid Cabin, 24V 440ah 6V GC battery bank, Xantrex MPPT60-150 CC, Magnum MS4024 inverter-charger, >1200w Solar bank
Re: Panel Mixing, please comment on my proposal.machineman wrote: »Ok thanks. This is good news, its been tough to find panels close to my odd ball Evergreen ES-A string Vmp. So I don't need any diodes or anything between the strings?
Nope. With only two strings you don't even need fuses on them.
