Another New Guy wiring question
srhill
Registered Users Posts: 8 ✭
Hi,
What I would like to do is: run a DC line from a ground mount pv array(8.5kw) 200 feet to my garage, install the SB8000 inverter there, then run AC 200 feet to the house.
My problem is what do I do about combining and fusing the 3 strings at the array since the SMA DC disconnect / fuse box is intended to mount on the inverter and not as a stand alone unit ? Am I going to need to locate the inverter (& DC disconnect) waaaay out at the array ? Or is there another low cost option...
thanks so much !
thanks so much !
Re: Another New Guy wiring questionHi,
thanks so much ! -
200 ft is a lot of $ in copper. Why you reconsider mounting the inverter on a side of the house closer to the array. The SB8000 is suitable for outdoor use. -
Is it 200 ft. to garage and another 200 ft to garage meaning your house is 400 ft from panels? Or is ithe house 200 ft. from panels? I was going to install an inverter at the garage as you proposed. It was closer to my house from the panels to the house as my house was between the panels and garage. So I put the inverter in the house in my utility room. That way I only needed a 250 ft dc run from my panels to inverter and about 12 ft of 240 vac to service box from inverter. Like fellow in post # 2 recomended you need combiner box at panels. On mine I used the safetouch fuse system in the combiner box and run positive wire out of combiner box to 600 vdc shutoff at panels. My inverter is a fronius and I never hear it running. If I would have run to garage I would have had about a 400 ft run of dc wire and aproximatly 100 ft of 240 ac wireing. Solarvic -
Thanks everyone for the advise. To clarify things, the distance from my house to the array is 400 feet with the garage right in the middle (@200 feet) -
Re: Another New Guy wiring questionThanks everyone for the advise. To clarify things, the distance from my house to the array is 400 feet with the garage right in the middle (@200 feet)
- 654 Solar Water Pumping
