Source for single 10awg stranded copper UV rated?
DSinOR
Registered Users Posts: 18 ✭
Where can I buy single 10awg stranded UV rated for rooftop combining, sold by the foot? I only need 20' each of red and black.
Thx!
Thx!
Re: Source for single 10awg stranded copper UV rated?
From some earlier posts on the forum--You probably will only find black UV rated wire--No other colors.
The typical solution is to use rolls of colored tape to mark the last 6-12 inches of wire as it enters the box.
or 'heat shrink' in red or other preferred colour
Okay - any links to a source for black UV wire by the foot?
Thx. -
Hi DS,
Often MC Extension Cables are used .. buy about twice the length than you need, and cut it into two sections:
http://www.solar-electric.com/incaforsoelp.html
The Host of this Forum seems to NOT stock #10 AWG XLP, has the proper rating for direct exposure.
FWIW, VicOff Grid - Two systems -- 4 SW+ 5548 Inverters, Surrette 4KS25 1280 AH X2@48V, 11.1 KW STC PV, 4X MidNite Classic 150 w/ WBjrs, Beta KID on S-530s, MX-60s, MN Bkrs/Boxes. 25 KVA Polyphase Kubota diesel, Honda Eu6500isa, Eu3000is-es, Eu2000, Eu1000 gensets. Thanks Wind-Sun for this great Forum. -
Hey, that what I needed! "XLP".
I found a couple places selling it for 50cents per foot.
Here some in white http://www.solarpanelstore.com/solar-power.wire.tray_cable.pv_10awg_wht.info.1.html
Thx! -
FWIW, John Wiles recommends using only black PV wire even if other colors are available. He has data to support his opinion that UV eventually breaks down the other colored insulation.From some earlier posts on the forum--You probably will only find black UV rated wire--No other colors.
-Bill -
the use of colored tape or shrink tubing on the wire ends can be used to identify the +. -
ontility.com
ebay.com
directpv.com
lots of places.
