What is Home Run wiring?
Rybren
Solar Expert Posts: 351 ✭✭
I've seen folks post about Home Run wiring a number of times - like this one -
what is Home Run?
thanks
Using good shield wiring running (home run) back to the battery bank
what is Home Run?
thanks
Re: What is Home Run wiring?
Daisy chain wiring is from the battery to load A to load B to load C.
Home run is one wire run from Battery to load A, a second wire from battery to load B, third wire to load C... Home runs can reduce noise from one load (or charging source) causing noise/interference on another connected device.
Thanks Bill, appreciate the help.
