Hooking up two panels
mcgraw58
Registered Users Posts: 2
Brand new question:
I want to get two 5-watt panels for an RV. Each has a 12-volt male connector. Can I plug them into a "Y" and then plug the Y into a single 12 volt female recepticle and get both to charge the two parallel RV batteries simultaneously? If so, will this speed up the charge cycle over a single panel?
As you can see, I am a true expert wannabe.
Thanks,
mcgraw58
Thanks,
mcgraw58
Re: Hooking up two panels
Yes it will... But 5-10 watts is closer to trickle charging for storing a battery rather than giving you very much power to run loads.
Re: Hooking up two panelsYes it will... But 5-10 watts is closer to trickle charging for storing a battery rather than giving you very much power to run loads.
Thanks. Right now I'm after more of a trickle charge, but any more would be a bonus even if small.
Kim -
Trickle-charge is kind of a misnomer. At best, the typical setup like this is a "maintainer", just barely able to offset the natural self-discharge of the battery. Basically it helps to just keep the battery in the state the panel first found them in. Fully charging the battery at first is a must - otherwise if you start out with a half-dead battery, when you go to check on how well the small solar-maintainers are doing, the batteries will still be half dead - probably more due to sulfation since there is no REAL charge taking place. There may be a slight surface-charge to fool your voltmeter, but as soon as you put a load on it - it's gone.
- 230 Forum & Website
