System sizing checkup
New_Climber
New_Climber Registered Users Posts: 12
I have a garage/shop/barn that currently doesn't have any electric wired to it. I have been using a 100ft ext cord to get some power for lights.
I am wanting to install a small solar system to be used for all my overhead lighting. My load I currently foresee is 10 - 13w CF over head lights of which I see using for about 5hrs per day, for half the week.
So, is my calculation correct that I will need 650w of capacity (13w*10ea*5hr)?
Then for battery capacity: 32XHS-12v has 105ah at 5-hr rating....This battery gives me 1260watts total over 5hrs? (am I reading the battery information correctly)?
As for panels, I already have 2-Grape solar 185w, 36wmpp....So to make a rough estimate of how much power these can produce I just took total rated power and halved it...so I can make about 185w/hr. I live in the pacific northwest so using peak sun of 3.5hrs per day, I can produce about 640w per day.
Questions:
Are my calculation remotely correct? Also, I am not sure if I have enough power production to recharge my batteries, especially in the winter when I get the least amount of sun?
I know I also will need an inverter and charge controller, but I just want to see if I was on the right path to start with?
Thx for the help?
    Re: System sizing checkup
    Honestly, I would dig a trench and bury some 3 conductor+ground 10 AWG or 8 AWG direct burial cable (I think code is 18" deep minimum) and bring 120/240 VAC to the shop.
    Then look at solar for the education/backup power...
    • 650 Watt*Hours per day.
    Nominally, recommend 1-3 days of "no sun" plus 50% maximum discharge for long life. For 2 days of power:
    650 WH * 1/12 volt battery bank * 2 days no sun * 1/0.50 max discharge = 217 AH per day
    You can go with 105 AH @ 12 volts, but you will only have one day of "no sun" carry through. And a bit shorter battery life--But it is certainly a valid configuration.
    2*185 watts * 0.52 system eff * 3.6 hours of sun per day = 692 WH per day of 120 VAC power (approximately)
    Note that you should never plan on using 100% of your power every day--But if you go in the shop every other day, you will be OK.
    Questions:
    If you are on the cost, the amount of sun can be terrible. Using PV Watts fixed array tilted to latitude for Quillayute WA:
    Month    Solar Radiation
    (kWh/m 2/day)
    1      1.51
    2      2.21
    3      3.12
    4      4.04
    5      4.73
    6      4.74
    7      4.91
    8      4.57
    9      4.37
    10      3.31
    11      1.87
    12      1.85
    Year      3.44
    So, yes, during winter you may need a lot more panel or use a lot less power. That Marine layer is a killer.
    The Rogue 30 amp MPPT controller would be a great fit.
    The MorningStar 300 watt 12 volt TSW inverter is the best small / 12 volt inverter out there right now.
  • New_Climber
    Basically, I am using this solar system more as an education lesson then to get power to the shop. The battery I quoted, I already have for a travel trailer, and I have the panels, so I am somewhat half way there with equipment.
    As for your correction as quoted, you highlighted HOURS per day. With my plan, I would use 13w*10ea=130w per hour the lights are on. If I use them 5hr per day, isn't it a total of 650watts per day? Or are you correcting my mis-use of terminology?? Meaning 650watts total per days, should be stated as 650watt hours (wh) per day? As I have learned, using the correct terminology makes getting help so much easier.
    The confusing part is the Watts per Hour... Watts is already a Rate (like Miles per hour). There is not a Watts per Hour (--actually there is, it is the equivalent to acceleration or ft/sec2).
    Multiply Watts * Hours gives you Watt*Hour which is equivalent to MPH * Hour = Miles driven.
    I understand the desire to learn more about solar by starting with a small system... Your system will work fine (within its limitations).
    PS: Watts are already Joules Per Second (J/S)... And somebody decided to call the "derived unit" a "Watt".
    Sort of like naming Miles per Hour a "Bill". And Bill*Hours would be miles driven. :p
  • vtmaps
    Power is measured in watts, and is a rate of energy usage. WattHours is an amount of energy.
    that's 1260 watthours or 1.26 kilowatthours
    No, its 650 watthours.
    So your load is 130 watts. Your inverter must be sized larger than that because the power factor of CFs is less than 1. May I suggest the morningstar suresine 300. Also, no inverter is 100% efficient. Therefore you will be drawing more than 650 watthours from your battery every day. That's more than 50% of your battery's capacity and will shorten your battery's life.
