5 Reasons Your Off-Grid Solar Lighting System Fails
RSSfeed
Registered Users Posts: 3,810 ✭✭
5 Reasons Your Off-Grid Solar Lighting System Fails Whether you purchase large off-grid commercial solar light systems or smaller off-grid *home solar light systems, there are generally only a handful of reasons these lights will fail. *Hopefully after reading this list you will be able safeguard your off-grid solar lights against failure thus ensuring many, many years of trouble-free operation. 1. Solar Panel [...] Solar Feeds
go to solarfeeds for the rest of this story>>>>>
More...
More...
Re: 5 Reasons Your Off-Grid Solar Lighting System Fails
Duuuuuh!! I can't believe it...
Re: 5 Reasons Your Off-Grid Solar Lighting System Failswestbranch wrote: »Duuuuuh!! I can't believe it...
On the question of which panel faces South, how about neither of them? One East and one West so that they do not face each other's light emitters? No rule saying they have to charge at the same time or even that maximum panel output is needed.SMA SB 3000, old BP panels. -
Houston has solar parking meters all over downtown. Some of them are under trees and some are only a sidewalk's distance from the north sides of very tall buildings. Those units will NEVER see the sun. What were they thinking? -
Re: 5 Reasons Your Off-Grid Solar Lighting System FailsHouston has solar parking meters all over downtown. Some of them are under trees and some are only a sidewalk's distance from the north sides of very tall buildings. Those units will NEVER see the sun. What were they thinking?
What do you mean "thinking"? It was a government job! No thinking allowed!
Engineer who designed it was supplanted by a tree planter...;)
