Battery question
RedNeckSolarMan
Solar Expert Posts: 34 ✭
Hello everyone, I have question on batteries. Reason for question is, actually a debate with my cousin (car mechanic). He seen my small solar system and I told him my little problem with battery being too big for system. He recommend since I am running only DC rope lights is use a motorcycle battery. They are low amp batteries that are used for motorcycles. Plus since he stated that my charge controller looks like a small slow charger, and the motorcycle battery will handle it. But he said if I put in another solar panel (currently running 80 watts total), I may have to put back my small marine battery in.
I trust my cousin with my car but with solar system, I don't know about it. So I thought I get you guys opinion about it. Thanks
FYI, also thanks to everyone who as responded to my threads in past. You guys are a big help, thanks.
Re: Battery question
Some of us have poor memories (don't remember the details of your previous posts) and are lazy (don't feel like doing a search). It would help if you remind us what you have when you start a new post, better yet is to make a sig line. --vtMaps4 X 235watt Samsung, Midnite ePanel, Outback VFX3524 FM60 & mate, 4 Interstate L16, trimetric, Honda eu2000i -
The battery talk was from a problem I had.
http://forum.solar-electric.com/showthread.php?16226-Need-Help-on-Solar-System
But I have posted threads in past but most of time, I just come to this website and read and get ideas or/and learn. -
In that other thread you were advised that 80 watt panel would charge a 50 AH battery. So whats the AH capacity of the motorcycle battery that you are thinking of? Also, the motorcycle battery is not a deep cycle battery and will have a short unhappy life in your system. --vtMaps4 X 235watt Samsung, Midnite ePanel, Outback VFX3524 FM60 & mate, 4 Interstate L16, trimetric, Honda eu2000i -
Re: Battery questionAlso, the motorcycle battery is not a deep cycle battery and will have a short unhappy life in your system. --vtMaps
Exactly, you need a deep cycle battery.
I wouldn't worry about having a battery that is "too big", as long as you are replacing the amps you are withdrawing within a day. The problem comes when you draw the battery down too far and your PV is too weak to recharge it on most days.4.5 kw APC UPS powered by a Prius, 12 kw Generac, Honda EU3000is -
Re: Battery questionExactly, you need a deep cycle battery.
I wouldn't worry about having a battery that is "too big", as long as you are replacing the amps you are withdrawing within a day. The problem comes when you draw the battery down too far and your PV is too weak to recharge it on most days. -
Implied in "the amps you are withdrawing within a day", but stating that explicitly doesn't hurt either. Bottom line, it doesn't matter how big your battery is as long as it is being fully charged on most days.4.5 kw APC UPS powered by a Prius, 12 kw Generac, Honda EU3000is -
Ok, pretty much I need low amp battery. I did some pricing on 50 amp hour battery. holy smokes, almost 175 dollars. my other idea is another solar panel. but that idea is not available at this time (due to room on balcony). Can i get away with lawnmower battery until go get overpriced battery or get another solar panel. -
Re: Battery questionImplied in "the amps you are withdrawing within a day", but stating that explicitly doesn't hurt either. Bottom line, it doesn't matter how big your battery is as long as it is being fully charged on most days.
- 231 Forum & Website
