pumping on level ground
lazza
Solar Expert Posts: 336 ✭✭✭
HI
I'm trying to calculate the energy requirements for an off-grid pump. I know the following formula for calculating energy requirements:
P=Q*H*9.81/ɲ
where P= Power in Watts
Q= capacity in litres/second
H= height in meters
ɲ= efficiency of the pump
But how do I calculate the energy requirements to pump along level ground?? (for example... to extract water from a 10m deep well, then along 25m of level ground and then a further 3m meters to a header tank)
Cheers
Larry
P=Q*H*9.81/ɲ
H= height in meters
Cheers
Larry
Re: pumping on level ground
You need to include friction loss for the pipe which varies with pipe size, pipe material and velocity. Thereare some rough formulas but most folks look it up in a book.
If you dont mind English units, look around for a used version of Camerons Hydraulic, any edition will do.
- 230 Forum & Website
