Wiring for my cabin?? Outside from panels to the 'wall'..
ywhic
Solar Expert Posts: 621 ✭✭
I have a small 12x24 shed/cabin.. in way South Texas.
I have/will have 6 panels outside mounted on some cinderblocks anchored with concrete to the ground.. I get 1-2" snow per year..
I have 150' of PV/USE-2/XLPE/600V UV/Sunlight Resistant rated wire 90C wet or dry..
I plan on bringing the wire runs into the cabin and thru the 3/8" plywood type wall to my QO combiner box (indoor rated) with breakers..
Can I just bury (about 6" below ground) the more exposed sections of wire till I get to the wall.. then just route them thru a basic outdoor rated gang box to make the jump to the inside??
That was the reason for buying the above type wire..
I don't think I would need any type of conduit on this, do I??
And if so can that gray (looks like PVC) be ok to use?? I'm thinking yes..
The panels are NOT roof mounted so I don't know if that matters (or not)??
Anyone done this have some simple pics to show how they did theirs??
Re: Wiring for my cabin?? Outside from panels to the 'wall'..
are you running 150' from the pv to the combiner box? i thought the combiner box needed to be as close the pv as possible... -
No.. max is 15 feet of wire for EACH panel (rated at 8.05 IMP) using the 10 AWG PV wire mentioned in my OP..
I bought 150' of the wire to make custom 'runs'..
3 panels at 11 feet from rear wall (OAL run of 15')
3 panels at 6 feet from rear wall (OAL run of 10')
These measurements includes the 4' length of wire to climb UP the wall once inside the building.. -
Anyone?? -
you're off grid and there are no code zombies that can say anything, so why not? If you want to make sure, I'd run it through some conduit for added peace of mind, that stuff is so cheap I'd do it just to make sure. -
As I understand, the "standard" it to bury power lines at least 18" deep... And if you have animals in the area that like to chew, using metal conduit/boxes above ground is probably not a bad idea.
Unless it is direct burial wire, as you did not state. Then yes, install the wire inside PVC tubing. I don't know about there in W. Texas, but here in Az., the little gophers will chew through anything that's not protected. My underground telephone wire proved as such. Put it in PVC. Forgot to add....that when you finish your setup, take a break. Go to Sooky's Bar in Van Horn and have a few beers. Make sure you know just a little Spanish too. -
Re: Wiring for my cabin?? Outside from panels to the 'wall'..Unless it is direct burial wire, as you did not state. Then yes, install the wire inside PVC tubing. I don't know about there in W. Texas, but here in Az., the little gophers will chew through anything that's not protected. My underground telephone wire proved as such. Put it in PVC. Forgot to add....that when you finish your setup, take a break. Go to Sooky's Bar in Van Horn and have a few beers. Make sure you know just a little Spanish too.
Says direct burial as well according to the mfg..
Gonna use something I guess for the underground part just for added assurance..
I know enough to order a servasa and goto the banyo. (and yes I know the spelling is wrong).. :cool:
I just kept reading something about conduit thru the wall if going inside.. yada yada..
Any suggestions on how to get it THRU the wall?? figure I have 6 pairs of 10 AWG 6mm OD wire.. -
That's all the Spanish you need to know there.......good! On the wiring, use a metal box at the wall penetration. You'll be OK. -
Re: Wiring for my cabin?? Outside from panels to the 'wall'..That's all the Spanish you need to know there.......good! On the wiring, use a metal box at the wall penetration. You'll be OK.
Have any specific suggestions on that?? I would think a double gang would be ok size wize..
I would guess a rear knockout would be needed also.. (as you can tell I am clueless).. -
If you're going to bury a portion of the wiring in PVC or whatever to the cabin.....what I would do is use a elbow of the same material, (PVC) come up from beneath the depth of burial into the bottom, exiting via the back of a metal gang box. The box, itself will hide any outside blemishes. There drill, dremel-tool, chisel, and go through the wall as neatly as possible, insert another piece of PVC into the cabin wall, attached to the metal box. Seal around the box with a good quality caulk. From that point on it's strictly cosmetic appearance inside according to your liking. I'd use the same size wire I ran underground to do the thru wall insertion. Inside you can go up the wall, or insert a receptacle box and make your run from there to wherever you're connecting to. The wiring can be hidden between furring strips, and covered.
Don't worry about being clueless. If you've never done it before....then you've never done it before. Simply strive, attempt to make things as neat as possible. -
Maybe something like this in 1 1/2" or 2" flavor.. come up from the bottom and then in thru the wall??
Got to remember I have 6 pairs of 6mm OD wire.. so a 1/2" or 3/4" hole/knockout isn't going to work.. (I don't think)..
ETA: found plastic Carlon 1 1/2" version for under $6 at HD website. :cool: -
There's nothing wrong with using that setup. Just make sure it is well stabilized. Is it metal? No, a 1 1/2" or 2" diameter won't work. If the wires are as you say....then, that's roughly 2.8" in diameter that you presently have. You will need 3". The simple remedy is to use two, side by side, and split the pairs in half. At that rate, you're going to have to use 3" PVC for all, or run seperate PVC's. From the output of the PVC you will need a reducer. Two of them to fit their respective boxes. Wrong Info.......please delete. -
OK, First, Al's pic just above is a Rigid SLB fitting (metal)
Believe that the wire that Al is using is 6 sq MM, about #10 Ga AWG which is about 0.250" OD, depending on the exact wire.
I do not have my NEC Bible here, but, technically, the wire should not exceed the recommended maximum fill for the conduit used. Will poke around on the net, as time premits to see what I can find, altho I seldom do Metric.
VicOff Grid - Two systems -- 4 SW+ 5548 Inverters, Surrette 4KS25 1280 AH X2@48V, 11.1 KW STC PV, 4X MidNite Classic 150 w/ WBjrs, Beta KID on S-530s, MX-60s, MN Bkrs/Boxes. 25 KVA Polyphase Kubota diesel, Honda Eu6500isa, Eu3000is-es, Eu2000, Eu1000 gensets. Thanks Wind-Sun for this great Forum. -
Neither do I use mm Vic. I just calculated out what he said he has. That was 6 pair of 6 mm wire, (72mm). Equating to roughly 2.8" of diameter for the whole bundle of wires together. HOLD ON!! Alex and Vic I stand to be corrected....I was sorely mistaken. I get these darn pairs mixed up with other stuff. It would be 36mm bundeled together, equating to 1.4" dia. Yes Al, the 1.5" SLB fitting would work, unless you are worried about NEC, and the over-crowding of wire within the PVC or fittings. I will now chastise myself the rest of the week, and have some more toddy's! -
"USE-2"
USE = Underground Service Entrance.
The "2" means it is listed for 90° C.
Bury it at least 18", or if it goes under a road or driveway 24". Where it comes out of the ground, sleeve it in pvc.
Voilà! NEC compliant!
Back fill gently. (With sand if you have it.)
-Alex Aragon -
Decided 1 1/2" PVC up the wall to a PVC entrace box (like the above).. couple of 1 1/2" PVC straps to fasten to the wall..
If I go with 24v system I'll only have 3 sets of wire and not 6 initially.. so they will be some extra room in the TUBE..
I may throw a 10' section of PVC under the ground also.. and do a 90 deg to come up to meet the above..
Thanks for the reply folks..
- 425 Caravan, Recreational Vehicle, and Marine Power Systems
- 651 Solar Water Pumping
- 611 Discussion Forums/Café
