What a "cool" opportunity load... :)
                    RandomJoe
                    Solar Expert Posts: 472 ✭✭✭
                    I mentioned before I finally got the off-grid / backup subpanel tied in to several circuits in the house.  That put the subpanel next to a mini-split I had installed for my "server room" back when I used to run lots of high-temp computers.  Haven't used it in quite some time, and was even going to remove it when I painted the room a few months back...
Of course I realized then I had a perfect opportunity load for my solar panels! I'm usually floating by 1PM, with several hours of prime solar hours ahead. Since I am now on the "peak demand" plan with the power company I don't run the main house AC from 2-7PM. So I wired the spare circuit breaker to the mini-split.
The mini-split is nothing special - a 9000 BTU basic model, not inverter type. Runs like a dream on the inverter. I did get a bit of a thrill when the Mate captured a wattage reading on the inrush, something over 5,000W! Otherwise, between my always-on afternoon loads and the AC I'm drawing 1300-1400W (fridge cycling on/off) with it running.
Had all kinds of fun testing it out last week, every time I tried running it the clouds moved in! But today is clear and sunny. Got home around 1PM and turned it on, been running ever since - just now, at 5:30PM, the input watts are finally falling below output and my office is a brisk 68 degrees!
  The rest of the house is staying considerably cooler too, it's usually nearing 80 by now but still just 76.
Now I just need to wire up a relay, hook it to the automation system, and add some programming to fire it up after the system floats.
I've also been rereading the inverter AC thread with renewed interest!
Almost 9 kWh produced from a 2kW STC array so far. Still a couple more (waning) hours of sun to go.
            Re: What a "cool" opportunity load...
Awesome! That's a great situation to be able to take advantage of! -
you could also turn the furnace fan on manually to spread the 'cool' around the house too.
Don't forget, it isn't just floating when you've got unused energy. Depending on how long your system absorbs you can start some opportunity loads while in absorb. I do that with my water distiller and MX60 relayed outlet. Not right at the beginning of absorb, but after an hour or so a 1000watt load can be carried (an hour before float and some number of watt hours salvaged|).
Ralph
 - 232 Forum & Website
