Vtoc and Vtmp units in nameplate ratings
konstantin.neo
konstantin.neo Registered Users Posts: 19
While using the outback string sizer I have noticed that Vtoc and Vtmp units given by pv manufacturers can be Volts/°C or %/ºC
The Vtoc and Vtmp values that the String Sizer uses have units of Volts/°C.
How can I convert %/ºC to Volts/ºC ?
Thanks.
    BB. Super Moderators, Administrators Posts: 33,734 admin
    Re: Vtoc and Vtmp units in nameplate ratings
    Take:
    • Voc * %/oC * (1/100) = Vtoc/oC
    • Vmp * %/oC * (1/100) = Vtmp/oC
    and you should be OK (as I understand).
  • konstantin.neo
    Voc=37.64
    Vmp=30.5
    Voltage temp coefficient -0.35 %/°C
    Vtoc= 37.64 V / 100 * 0.35 = 0.13174
    Vtmp=30.5 V /100 * 0.35 = 0.10675
    I did like this, I guess that is correct.
    Just to clarify--I would write the equation this way:
    • Vtoc = 37.64 * -0.35 / 100 = -0.13174 V/°C
    • Vtmp = 30.5 * -0.35 / 100 = -0.10675 V/°C
    So you don't have the confusion of order of operation:
    • Vtoc= (37.64 V / 100) * -0.35 = 0.13174 correct
    • Vtoc= 37.64 V / (100 * -0.35) = 0.13174 incorrect
