Large Scale Ground Mount Systems
Philip C
Solar Expert Posts: 45 ✭
What racking company would you use for large scale ground mount systems, 100kW+
The cost of labor is a significant factor also.
Philip
Philip
Re: Large Scale Ground Mount Systems
Not that I can help you with a recommendation, but is this going to be in the Milwaukee, WI area?
No the Milwaukee job is not ours. Looking at different systems today, it appears some are driving an I-Beam into the ground. This seems like it can reduce labor cost quite a bit.
Got another question, are solar trackers still feasible? With Module prices hitting sub $1/W, its hard to believe one would want to deal with the hassle of moving parts. They say it can deliver up to 25% more energy. My guess is that the initial investment would have to be under 10%, as service and maintenance is increased also.
Philip -
Its easy to compare the tracker system cost to PV panels, probably will fall in favour of more PV and no hassles...
Here is an older thread (2009) about:
Solar Trackers for PV -- Worth it ?
"Dave Sparks", and installer that specializes in Off-Grid systems in the California Sierra Nevada Mountains still likes trackers because of better battery life (more hours of charging during the day)...
You may also be able to make a case if you have grid power and Time of Use metering (can be as high as $0.50 during summer afternoons in my area of California) vs the $0.09 for bottom tier off peak net metered power.
- 231 Forum & Website
