Power and Energy and the Battery FAQ
vtmaps
Solar Expert Posts: 3,741 ✭✭✭✭
Many solar beginners confuse power (Watts) and energy (WattHours), and our moderators and forum members spend a lot of time explaining the difference. This morning I reread the Wind-Sun Battery FAQ and found this quote:
Someone should correct this.Batteries are not 100% efficient - some energy is lost as heat and chemical reactions when charging and discharging. If you use 1000 watts from a battery, it might take 1050 or 1250 watts or more to fully recharge it.
Re: Power and Energy and the Battery FAQ
Thank you for find that vtMaps... I have sent our hosts a copy of your post.
