connecting small wind turbine directly to a light bulb.
Arashi
Registered Users Posts: 12 ✭
I have a small turbine. Puts out maybe 150watts if the wind is blowing well, I've never seen it produce more than 17volts. Could I just wire it directly into a 12v 100watt lighting fixture ...to get a little light in my back yard when it's spinning?
I have a battery bank, charge controllers, dump load... all that good stuff, but it's packed away in a storage shed a couple hundred miles away. I wont be able to get to that stuff for another couple of months. Sort of wanted to put up my wind turbine, I like watching it spin!
Re: connecting small wind turbine directly to a light bulb.
Ideally, you can make or buy a current mode buck converter... Takes variable input DC voltage and outputs a steady state DC current for LEDs (within the ability of the input voltage and current). Here is one example:
http://www.candlepowerforums.com/vb/showthread.php?276105-High-efficient-5A-9A-Buck-Converter-for-SST-50-SST-90
Be careful about letting lead acid batteries sit for very long without applying a charge. They typically self discharge 5 ~ 10% a month. -
Arashi was that 17v under a load or with the generator output connected to nothing? -
Re: connecting small wind turbine directly to a light bulb.Be careful about letting lead acid batteries sit for very long without applying a charge. They typically self discharge 5 ~ 10% a month.
wow, I did not know that. I bet my batteries are dead.They had a full charge........ two years ago when I put them into storage.
Re: connecting small wind turbine directly to a light bulb.Arashi was that 17v under a load or with the generator output connected to nothing?
Yea, the batteries are probably toast... You can store flooded cell batteries for about 1 month without recharging... AGM batteries for about 3-6 months.
Hot and older batteries self discharge faster than new/colder batteries. For every 10C (18F) you cool a battery, a ~2x longer life.
Re: connecting small wind turbine directly to a light bulb.Yea, the batteries are probably toast... You can store flooded cell batteries for about 1 month without recharging... AGM batteries for about 3-6 months.
...any way to fix them? -
Charge them about about a 5% rate of charge until they bubble well (flooded cell--monitor Specific Gravity for each cell as they are at full charge--If the SG continues to rise, try discharge/charge cycle again until SG stabilizes at full charge)--Discharge--Repeat 2-10x--Then buy new batteries.
If they are AGM--Depending on brand, there are some slightly different charging recommendations.
- 228 Forum & Website
- 654 Solar Water Pumping
- 619 Discussion Forums/Café
