2 charge controllers
ws9876
Solar Expert Posts: 453 ✭✭✭
if you have solar and wind and have 2 C 60 controllers...do you wire both separately to the battery or combine them..?? do you have to have any diodes to keep current from going the wrong way..??
Re: 2 charge controllers
Each controller is wired separately to the battery ,if you have a PMA turbine then you do not need blocking diodes. You need one common dump load.8)
