Can panels actually get better?
solar_dave
Solar Expert Posts: 2,397 ✭✭✭✭
So it is only mid March, today temps are cool here in the low 60's, we got some nice clean rain yesterday, my panels are hitting the max output on my inverters at 11AM today. Granted the conditions are pretty ideal today, panel temps are right at 70F.
I have never seen this before, could the panels actually be improving in output? The output is actually about 10% above what PVwatts predicts.
Re: Can panels actually get better?
No--However, cool weather with very clear skies--and even skies with some light haze have made my system produce more.
I have seen different models/revisions of GT inverters produce more/less power... The later Xantrex GT series seems to produce better than the 5-7 year old versions (unless they just say they perform better--Solar Guppy said the original GT inverters had accurate logging--presume the newer versions still do too).
PVWatts is actually a bit pessimistic if you use the default derating.solar_dave wrote: »I have never seen this before, could the panels actually be improving in output? The output is actually about 10% above what PVwatts predicts. -
I just waded through the hourly data and saw an hour @ 10200 watts when derated to 0.81. So I guess it is not far off. -
Re: Can panels actually get better?PVWatts is actually a bit pessimistic if you use the default derating.
This. PV Watts generally underrates production by 10-15% if not sometimes more. -
Of course, by putzing around with the derate factor you can make PVWatts say just about anything.This. PV Watts generally underrates production by 10-15% if not sometimes more. -
Solar panels (mono's otr poly's) o/p are rated @ 25 degC. As a rule o/p falls off approx 0.5% per deg increase of cell temperature. Below 25 degC o/p increases by this figure. If the panels are are on tilt frames with a cool wind blowing The cell temperature could drop below ambient -
Re: Can panels actually get better?Solar panels (mono's otr poly's) o/p are rated @ 25 degC. As a rule o/p falls off approx 0.5% per deg increase of cell temperature. Below 25 degC o/p increases by this figure. If the panels are are on tilt frames with a cool wind blowing The cell temperature could drop below ambient
I suspect this is exactly what is happening. Sun angle optimal in relation to mounting angle, temps cool, like today system peaked at 10,200 watts, previously it peaked the inverter max at 10,400. -
That doesn't make sense to me, unless you've got some sort of evaporative cooling going onIf the panels are are on tilt frames with a cool wind blowing The cell temperature could drop below ambient4 X 235watt Samsung, Midnite ePanel, Outback VFX3524 FM60 & mate, 4 Interstate L16, trimetric, Honda eu2000i
