air-x rewind drawing board
Thomas
Solar Expert Posts: 291 ✭
Does a 14AWG wind 14 turns sound good to replace Air-X windings? not nessisarily the controller?:-)
Always troubleshoot with adequate sunlight. Hi Ho Hi Ho
2.3kW [10] Enecsys SMI-240-60 micro inverters
Re: air-x rewind drawing board
14Awg Upon rconsideration seems big for low wind tower/goal, reconsidering winding double strand18-20AWG X 14-15 winds...BUT FIRST..
another effort at simpler solutions...Iam going to try to ground/the three remaining legs in wye,I have seen and read conflicting articles, it does not seem right to just leave them there, sucking air...if that douesn't work I have a few more Ideas compliments google, on Delta also. My Air -X is probobly head-toast but it does not seem right to just qiut on it, it is not crutial so re-winding later on only after more trials with 3 phase.Always troubleshoot with adequate sunlight. Hi Ho Hi Ho
2.3kW [10] Enecsys SMI-240-60 micro inverters -
This is the second time my low voltage-semi broken air X becomes disconnected. The first with a wye configeuration low voltage.. inside the turbine casing, this second time in my battert box, the connector to fuse was off.....why fix it when it only becomes disconnected.ArgghhAlways troubleshoot with adequate sunlight. Hi Ho Hi Ho
- 231 Forum & Website
