Ground Mounting and the Septic Tank
sub3marathonman
Solar Expert Posts: 300 ✭✭✭
I made one mistake when I had the house built, and that was putting the septic tank and drainfield on the south side of the house. This created another problem where I was forced to put the well on the north side of the house, instead of on the south side right by the electrical panel where it could have been used as a great grounding point.
Now, I'm wondering if there isn't another problem because of the placement.
Is it possible to put ground mounted panels over the area that the septic tank and drainfield use? Will the drainage be the same if the panels just let the water run down between panels?
I can't believe overlooking one thing out of thousands of details would lead to such problems.
Re: Ground Mounting and the Septic Tank
depends if you ever want the tank pumped out, a 'job' that needs done every 2 - 10 years depending on use and what gets put into that little biosphere...
You probably wouldn't want to cover the tank for the reason westbranch said. But I'd think the drainfield would be o.k. provided that whatever you use to anchor the panels to the ground isn't penetrating any of the drainlines or the gravel that surrounds them. -
My drainage field / perk off area is the best for growing , plus always needs weeding , the area is cool when were baking because of the plants and moisture.
Im glad that I built my above ground garden on it. There is a different garden for root crops , that is not part of the Septic perk field.
Just letting you know that those ares help plants grow, so consider that also.
VT -
Interesting, you have an underground garden? Are you a survivalist, ready for anything?
Also don't forget, tile beds sometimes need replacement. That would require moving your array, kind of like de-comissioning a roof mount to re-shingle.
Ralph
