home depot stranded wire ok for DC?
YostFMX
YostFMX Solar Expert Posts: 94 ✭✭✭
i bought some home depot 0 awg stranded wire for linking batteries together, the only thing is there is only 19 strands. each strand is pretty big, is that bad for DC? i used home depot 10 awg stranded wire (19 strands) for my little 45 watt panel on my rv. that works ok, not sure if there is a power loss? but it works... ill post a pic of the 0 awg tonight. the guy at home depot said people use it for AC...
    Re: home depot stranded wire ok for DC?
    A couple threads to check out:
    Suitable array to controller cable?
    Ampacity vs. cross sectional area
    Questions?
  • YostFMX
    From what I read you don't have to use stranded wire for DC. I was told you always had too! So this is fine than I guess...
  • Windsun
    The stranding of the wire has nothing to do with AC or DC, it is all a matter of flexibility and connections.
  • kevin
    kevin Registered Users Posts: 9
    it doesn't about use the stranded wire in AC or DC, the thing what you need consider is current.perhaps in most of the time,you can design 4A per Square millimeter.
  • oil pan 4
    Wire that size will be good in both the size and construction departments.
    How much power do you plan to push through it?
    Also see:
    http://www.powerstream.com/Wire_Size.htm
    When there is any quesion about wire size I go there.
    stranded wire can be used instead of solid wire where one wants more flexibility and resistance to breakage and does not have a dc or ac only statis. both solid and stranded wire can be used in both ac and dc applications
