please recommend clamp ammeter with accumulator
vtmaps
Solar Expert Posts: 3,741 ✭✭✭✭
I am looking to buy a DC clamp type ammeter. There are hundreds of models, can you recommend one? I don't know if there is such a thing, but it would be useful to have one with an accumulator (something that keeps track of current and time, and can give me an AmpHour reading. thanks, in advance,
Re: please recommend clamp ammeter with accumulator
Have never heard of one with the features you are looking for. -
Sounds like you might actually be looking for a battery monitor? That's the only thing I can think of that keeps track of current flow over time. Needs to be hard-wired in, though. A clamp-on meter would not be reliable in such an application as the zero point would be almost certain to drift. -
Re: please recommend clamp ammeter with accumulatorwaynefromnscanada wrote:Have never heard of one with the features you are looking for.
OK, Thanks. I will stop looking for such a device. I do have a trimetric battery monitor. I was looking for an easy way to monitor the energy usage of my DC fridge and freezers. I would like something similar to a kill-a-watt, but for DC current. Perhaps I will build one out of a battery monitor and shunt.Cariboocoot wrote:Sounds like you might actually be looking for a battery monitor? That's the only thing I can think of that keeps track of current flow over time. Needs to be hard-wired in, though. A clamp-on meter would not be reliable in such an application as the zero point would be almost certain to drift.
There are DC versions of the Kill-a-Watt... A couple (smaller amperage) ones are available here. They do not "record backwards"--so they cannot totalize current into/out of a battery bank.
They look perfect! I can hardly wait. Thanks so much for the link. --vtMapsBB. wrote:There are DC versions of the Kill-a-Watt... A couple (smaller amperage) ones are available here.4 X 235watt Samsung, Midnite ePanel, Outback VFX3524 FM60 & mate, 4 Interstate L16, trimetric, Honda eu2000i -
Fluke 374 and higher have a min/max/average function.4.5 kw APC UPS powered by a Prius, 12 kw Generac, Honda EU3000is
