perplexing charge controller readings
Re: perplexing charge controller readingsAha, now that would make sense-- although not sure what a "pico" fuse is.. and highly likely that the monkey that installed it reversed the polarity at first try (although these gadgets are supposed to have sufficient protection against it).. thanks for the input snuffy
Pico fuses....http://parts.digikey.com/1/parts-kws/pico-fuse
- 228 Forum & Website
- 618 Discussion Forums/Café
