anyone use the solmetric pva-600 pv analyzer tool?
rollandelliott
Solar Expert Posts: 834 ✭✭
PVA-600
http://www.solmetric.com/pva600.html
anyone use this expensive tool $2500?
If so why it is better than a multimeter? Would you recommend it?
Peace, Rolland
Peace, Rolland
Re: anyone use the solmetric pva-600 pv analyzer tool?
Its a hand held curve tracer
You plug in the panel and it measure the VI curve from open circuit to short circuit
With a DVM, you need an external load to make measurements -
thanks I read the spec sheet, just wondering if anyone has any real world expereince with it. we all know sometimes reality puts a damper on a spec sheet.
