XW MPPT 150 AUX ouput question
machineman
Solar Expert Posts: 129 ✭✭✭
If its night with 0 PV input will the Xantrex AUX output still function? Just wondering because I want to use this output to trigger another source depending on battery voltage.
Thanks.
Thanks.
Off Grid Cabin, 24V 440ah 6V GC battery bank, Xantrex MPPT60-150 CC, Magnum MS4024 inverter-charger, >1200w Solar bank
Re: XW MPPT 150 AUX ouput question
Works on mine........ -
The aux relay is powered off the battery so yes, it still works.
