Solar Panel makes- & grid-tie vs off-grid panels
lazza
Solar Expert Posts: 336 ✭✭✭
HI forum
We have been offered a very good deal for some solar panels, but they are makes that I am not familiar with (until now we have only been working with Kyocera)
They are yuraku (china) and bauer solarenergie (germany).
My questions are:
Thanks very much for any pointers
Larry
My questions are:
- Does anyone know these makes and will the panels be reliable?
- One is for grid (bauer) and the other (yuraku) off-grid. I dont understand the difference, surely as long as you use MPPT in the off-grid installation you can use grid-tie panels, cant you??
Larry
Re: Solar Panel makes- & grid-tie vs off-grid panels
I've never seen any reliability comparison studies for ANY panels, if there are some out there I'd love to see them.
And you can use an MPPT to make on grid panels usefull for off grid, but why bother if you don't have to. -
The two major differences between GT and Battery system panels are:- NRTL approvals (Nationally Recognized Testing Laboratories)--These are the ULs, CSAs, ETLs, TUV, etc. of the world. In North America, solar panels need to have NRTL approvals for building and fire code compliance.
- Output Voltage--Typically, for the less expensive PWM type charge controllers, the Vmp of the solar panels are Vmp~17.5 volts for 12 volt battery banks (or ~35 volts for 24 volt battery banks, etc.). This allows for the most efficient use of solar panel output power (on average). With modern MPPT type charge controllers, Grid tie panels Vmp which is usually >>17.5 volts is less important these days. And large Grid Tied designed panels are usually cheaper per watt than the (typically) smaller wattage panels designed originally for battery systems.
