Smartrack? (will NAWS sell it?)
DaylanDarby
Registered Users Posts: 9 ✭
Thanks everyone for the advice from the last post. I've been reading and planing and reading these last couple weeks to figure out a mounting system and came across Smartrack (which a search here hasn't discussed before), with an installation video here
Comments/concerns?
Anybody tight here with NAWS to see if they will sell it?
Comments/concerns?
Re: Smartrack? (will NAWS sell it?)
Pro: Lot easier to order, ship, and so on than long rails.
Con: WAY more roof penetrations, and thus, chances for leaks.
Panels will have to pretty much mount in "landscape" mode, as most roofs have 24" OC rafters, and most 200+ watt panels are in the 35-40" wide range, the clamp spacing will get odd real quick....it does anyway from the panels I've mounted on a standing seam roof, but you can live with it.
Panel is gonna be closer to the roof, more heat.
- 230 Forum & Website
