Mppt PWM and Hub1
santsalvador
Registered Users Posts: 12 ✭
HI all.
Is it possible to connect morningstar MPPT TS 60 and PWM TS 45 into the HUB-1 also using one TS-RM-2 remote meter.
Terry.
Terry.
Re: Mppt PWM and Hub1
i don't know if anyone here has tried such a combo and it might be good to ask morningstar just to be sure. let us know if you do get an answer from them. -
I believe you can.
From the Morningstar site:
http://www.morningstarcorp.com/en/meterhub
(The owners manual is there in pdf form)
Compatible With:
SunSaver-MPPT™
TriStar™
TriStar-MPPT™
TriStar Meter-2™
TriStar Remote Meter-2™
Relay Driver™Enables multiple controllers to share a single TriStar meter and display both single controller data (TriStar #1, TriStar #2…) as well as aggregated data for the entire system. -
HI. Had a reply from Morningstsr saying they are passing it on to their technical department, I don't see why not as they are isolated from each other but how the TS-RM-2 would react i'm not sure.
I'll let you know.
Terry. -
HI. Received this AM.
Hello Terry,
yes you can use a meter hub with the TS 60 MPPT and the TS 45 PWM on a single TS-RM-2. Use link below to config you system.
http://www.morningstarcorp.com/en/support/product.cfm?Name=MeterHub
Craig Edwards
Electronic Technician
Morningstar Corp.
So all seems OK, thanks all fr your input.
Regards Terry.
- 230 Forum & Website
