solar wand
ws9876
Solar Expert Posts: 453 ✭✭✭
anyone have one of these by Butler...???? what do you think of it..??? I guess they are 550$ now...
Re: solar wand
i think it's worthless for most applications. 1000a? i want to see how anybody would wire it as that would be outrageously big wire. -
Re: solar wandi think it's worthless for most applications. 1000a? i want to see how anybody would wire it as that would be outrageously big wire.
I didn't see a reference to 1000A anywhere, but many electrical heating elements for water heaters are 1000W; perhaps that is what was meant? -
Re: solar wand
Water heater elements are usually 3500 Watts, not 1000. -
Re: solar wand
my bad as i was looking at something else. senior moment. -
Re: solar wandCariboocoot wrote: »Water heater elements are usually 3500 Watts, not 1000.
Re: solar wand
its the glycol circulator folks -
Re: solar wandits the glycol circulator folks
To that end, I shouldn't think there's much surface area in an element-sized heat exchanger to do much transfer at the temperature available. In other words, I wouldn't expect the glycol unit to get as hot as an electric one. That doesn't mean it won't work, but expect the recovery time to be much longer. Probably better with a smaller tank.
And I did says water heater elements are usually 3500 Watts, not always 3500 Watts. Some of them are 4500, in fact; faster recovery time (at the expense of more electric of course).
- 228 Forum & Website
- 618 Discussion Forums/Café
