Panasonic sn960s
JESSICA
Solar Expert Posts: 289 ✭✭
Greetings:
Does anyone here owns this microwave oven: Panasonic SN960S?
It is advertised as an "inverter" oven and I have read that it is the only microwave oven that actually draws less power when used at lower leves (medium, low, etc.)
Is this true?
Is this true?
Re: Panasonic sn960s
Let's get out the ol' search shovel and dig!
We find this thread: http://forum.solar-electric.com/showthread.php?t=11684
And if you're patient enough to read through it the Panasonic inverter microwave did come out a winner - by a small margin. (Lots of irrelevant stuff in there too.) -
Please avoid the Panasonic Inverter microwave ovens, the reliability on them is TERRIBLE. The "Inverter" board, which derives the high voltage for the magnetron tube using what finally looks like a slightly redesigned television flyback transformer(?!), is very prone to failure and replacements cost more than a new oven.
http://applianceguru.com/forum1/347.html
This includes one of the Samurai Appliance Repair Man's famous haiku:Inverter Oven
Panasonic says its good
Fix it once a year!
You're better off using a conventional microwave with time-tested BHT technology: Big Heavy Transformer.
The way these regulate power is always, almost without exception, very low tech: the power to the transformer and thus magnetron tube is simply cycled on and off slowly. You can usually hear it cycling, sometimes with audible relay clicks, and always with a noticeable change in the light's brightness and the note of the cooling fan. An old-school microwave oven with a knob timer is preferable when running off grid as it will have *zero* phantom load and will not inhibit or misbehave with your inverter's search mode. -
My Panasonic inverter microwave has been going for years,No problems. Other family members have them also,no problems.2225 wattts pv . Outback 2kw fxr pure sine inverter . fm80 charge controller . Mate 3. victron battery monitor . 24 volts in 2 volt Shoto lead carbon extreme batterys. off grid holiday home
