panel mounting and point load
topper
Solar Expert Posts: 113 ✭✭
I am still in the pen and paper phase of my project.
I had 2 different installers come by. I need your 2 cents.
I am in the snow zone south Saskatchewan. Rafters are 2x4 truss rated for 50 lb/ft2 snow load.
Both systems sit on 3 inch unirack mounts with flashings.
One configuration uses 32 suntech panels on unirack sunframe at 4ft OC. This gives me a point load of 718 lbs. Seems rather excessive to me.
Estimated cost 5500.00.
The second proposal from the same installer is the same only @ 2ft centers. Point load of 359 lbs.
Est cost 7700.00
The second installer's configuration uses 36 panels on unirack solarmount at 2 ft centers. Point load is 266 lbs. Somewhat more reasonable to me.
Est cost 6700.00
Now engineering is telling me that all proposals are acceptable.
Given all of your knowledge and experience, I would really like your 2 cents. Dollars come second to safety and integrity of our home.
If any of you have worked with the "sunframe" or "Solarmount" , I would like your opinions.
Est cost 7700.00
Est cost 6700.00
Re: panel mounting and point load
Hi topper,
Have you gone to the UniRac site, and used the calculator yourself?
This link may work:
http://www.unirac.com/?q=residential/residential-products/solar-mount-residential
On this page, thre is a button in the upper third of the page "Configure Your Project"
It allows you to what-if some scenarios, and output Engineering data, if desired.
I do not know exactly what you mean by "2X4 Trusses". I am not in the snow belt, and used Uni SolarMount for a recent project, but this was on an over-designed 2X12 16" OC raftered roof. Given your snows, hope that your roof has a good slope to it.
Good Luck, VicOff Grid - Two systems -- 4 SW+ 5548 Inverters, Surrette 4KS25 1280 AH X2@48V, 11.1 KW STC PV, 4X MidNite Classic 150 w/ WBjrs, Beta KID on S-530s, MX-60s, MN Bkrs/Boxes. 25 KVA Polyphase Kubota diesel, Honda Eu6500isa, Eu3000is-es, Eu2000, Eu1000 gensets. Thanks Wind-Sun for this great Forum. -
Just punched in the designs and looks like the installers numbers are from unirack's website.
Rafters are 2x4 truss style @24" on center. 4/12 pitch=18.4* -
Topper, see my post regarding snow loads. If you post your snow loads I can give you what the reduced load would be.
- 234 Forum & Website
