Are there any string grid tie inverters in the 1kw to 1.75kw range?
rollandelliott
Solar Expert Posts: 834 ✭✭
I checked SMA and PowerOne and neither of them make an inverter in that range.
Suggestions?
Suggestions?
Re: Are there any string grid tie inverters in the 1kw to 1.75kw range?
Kaco: http://www.kaco-newenergy.com/products/solar-inverters/02x-series
Another one to check is Fronius, although their website was down when I looked. http://www.fronius.com/ -
Exeltech has model XLGT that is rated at 1800 watt. I have a fronuis IG-2000 that has a MPP voltage range of 150 to 400vdc that should work fine on on lower voltages. Maximum voc 500 vdc, nominal output ia 1800 kw ac and maximum is 2000kw. :Dsolarvic:D -
didn't see any inverters on this web site made by fronius
http://www.solar-electric.com/frigplgrin.html
that are lower than 2kw.
how much do these Exeltech and Kaco inverters cost per watt? hopefully around 50 cents?
Couldn't find pricing info without having to call a dealer. -
aparently you didn,t look very hard for the fronuis inverter I posted. Also SMA has a 700 watt inverter. http://www.solar-electric.com/friggrin.html The fronuis inverter is still for sale at lots of locations. I liked mine but took it off line as I had 16 kc-158 ppanels and the limit was 1 4 panels. So I bought the fronuis 3-0 inverter which can operate at higher voltage. Plan on using 8 180 watt and 2 175 watt panels on the ig-2000 since I can,t find any more of the panels I have. :Dsolarvic -
Where you can buy a Kaco gti inverter: Aten Solar :Dsolarvic:D -
thanks for the help
I'll check out fronius when their web site is back up
It's too hard to try and get info from dealers on the total product line.
I know about the SMA 700 inverter it is too small. thanks though. -
A bunch of manufacturers listed here: http://www.solarshop-europe.net/index.php?cPath=66
But not all will have US models available.
- 227 Forum & Website
- 618 Discussion Forums/Café
