SUCCESS!
cptdondo
cptdondo Solar Expert Posts: 106 ✭✭✭
OK, I just fired up my 270W array with the Morningstar Duo controller. 13A! Whee!
That should be plenty to meet my 20-50AH daily needs.
This is on a small RV, so the panels are flat on the roof. No tilt, so I expect more when the sun is higher in the sky. It's 2PM here right now.
Thanks everyone for the help and encouragement.
  • Thom
    Thom Solar Expert Posts: 196 ✭✭✭
    Re: SUCCESS!
    Good for you
    Thom
    Off grid since 1984. 430w of panel, 300w suresine , 4 gc batteries 12v system, Rogue mpt3024 charge controller , air breeze windmill, Mikita 2400w generator . Added 2@ 100w panel with a midnight brat
    Re: SUCCESS!
    congrats. the high point would be solar noon and is the time directly inbetween sunrise and sunset for the closest place listed to you. currently it'll be about 1:15pm for you if i see the right place for you, but it changes as the days go on so this will be fairly close to it for about a few days or so.
