Midnite solar AC bypass switch
offgrid
Registered Users Posts: 20 ✭
Hello all,
We just moved to a new location, during the move I believe the AC bypass switch on my Midnite solar E-panel box has been flipped up and down a few times. I have the system up and ready to turn on however, I am not sure if the switch should be in "bypass" or "invert". Sorry if this is a dumb question but any help would be appreciated.
Thanks !!
Thanks !!
Re: Midnite solar AC bypass switch
Hi Off,
I know nothing, but here is the MN E-Panel for OB page, it appears to have manuals:
http://www.midnitesolar.com/products.php?menuItem=products&productCat_ID=1&productCatName=Outback E-Panel
There is the MN Forum:
http://midnitesolar.com/smf_forum/index.php
Halfcrazy, the Chief Tech Support person for MN frequents this WindSun Forum, but the reply may be faster at the MN Forum, Good Luck, VicOff Grid - Two systems -- 4 SW+ 5548 Inverters, Surrette 4KS25 1280 AH X2@48V, 11.1 KW STC PV, 4X MidNite Classic 150 w/ WBjrs, Beta KID on S-530s, MX-60s, MN Bkrs/Boxes. 25 KVA Polyphase Kubota diesel, Honda Eu6500isa, Eu3000is-es, Eu2000, Eu1000 gensets. Thanks Wind-Sun for this great Forum. -
"INVERT" is for general solar operation.
"BYPASS" is for if your solar dies you can bypass it and put your loads directly on grid power.
This is a special breaker switch that prevents you from the catastrophic error of turning them both on at the same time. Invert or Bypass - not both!
- 234 Forum & Website
