Low watt compact toaster?
Mariner777
Solar Expert Posts: 29 ✭
Miss having toast for breakfast and making it on the propane stovetop is never quite as good as a toaster - the ones I looked at in shops were rated like 700 watts and up. My inverter is currently only 700 watts and none of them would run with it. Anyone know of a super efficient toaster?
Re: Low watt compact toaster?
Tony/Icarus here found an old propane catalytic heater that is the exact rectangular shape of a piece of bread... I think he still uses it to make toast.
Ah... Found it (and some other toasting suggestions on that same thread:We've been perfecting the toaster off grid for years. (Coleman does make a LP powered toaster oven, sort of a small camping oven. It didn't work for toast at all, but probably would work OK as a small oven, but I don't think it would save any energy relative to a conventional insulatedgas oven).
So we have tried every kind of camping/non electric toaster option out there. Far and away,,FAR AND AWAY! the best toaster option we have found is a small camping catalytic heater. The problem is that most of the new ones are round and not very conducive to toast which is,,square. My neighbour (also off grid) has a Coleman Canada model that I have coveted for years. It is rectangular, ~8"X6" with a wire grill 1/2" above the catalyst mat. (Just the right size for 2 pieces of toast! These have not been made in a number of years so they are VERY hard to find. It took me 5 years of regular searching to find one on Ebay! It works great! Light it, it glows red in about a minute, drop the toast on, turn it after about a minute and it is the nicest golden brown you can every imagine!
Susan thinks I'm crazy the way I show my toaster off to folks who stop by, but I think it is the coolest thing since sliced bread. Previously I had made one out of a newer generation round Coleman heater, works, but not nearly as well.
So search Ebay every now and again, look for a small square catalytic. If you find one, you will probably have to bid against me!
Remember, the ahs you burn up in a toaster are ahs you have to replace. You could argue that you like toast so much that adding extra Pv capacity to make it is worth it. In my case, I use about $1 worth of propane per year for perfect toast. Gotta make a lot of toast to justify $3/watt Pv.
TNear San Francisco California: 3.5kWatt Grid Tied Solar power system+small backup genset -
How about a 12V model?
https://www.skingco.com/pc-19-20-1615-empire-travl-toast-12-volt-toaster.aspx
$20. Plugs into your vehicle's cigarette lighter with supplied power cord, draws approximately 13Amps
First piece of bread
5 minutes - lightly toasted
7 minutes - medium brown
Second piece of bread
5 minutes - medium brown
I don't have one, but might be worth considering, especially for the low cost.
- 234 Forum & Website
