This SOLAR PLAN MUST be Possible>>
Re: This SOLAR PLAN MUST be Possible>>There's nothing special about high SEER AC units being worse than low SEER AC units at removing moisture. If it's not removing enough moisture that's likely a setup problem where you've got too much AC so AC cycle times are not long enough to remove the moisture (your AC unit is too big).
Re: This SOLAR PLAN MUST be Possible>>Blackcherry04 wrote: »I have to agree with this one. I just replaced a 4 ton heat pump with a 3 ton. Not only has my electric bill dropped, but the house is much more temperate and comfortable. 15 years ago they used much different heat load calculations and I'v made improvements in windows and insulation, that said the company wanted to put a 4 ton unit back in and be safe and for me to pay for it for the next 15 years. Today I have a 20 + degree temperature differential between in and out and the unit is cycling.
GP -
Re: This SOLAR PLAN MUST be Possible>>GreenerPower wrote: »The hi SEER design is quite different from the traditional design in the past. The refrigerant flow rate, evap. temp, air flow are all tuned to apply the heat extraction to air latent heat removal and minimal on moisture condensation. That's how they've got hi SEER. Those units in ~100% humidity climate as ours would get the air out at low temp but still high in humidity. As the result, home owners would set lower thermostat temp to get more "comfortable". Installers can tweak to some degree to get more moisture out but that would result in an overall lower SEER system. Putting extra money to get a hi SEER (> 20) in our climate is a waste, IMHO.
Your typical way too oversized AC unit will simply not remove enough moisture from the air. Multi/variable stage units may help hide the drawbacks of an oversized system, but way too many HVAC techs insist on installing an oversized system when a much smaller system will be more efficient and provide more effective humidity control thanks to longer cycle times. -
Re: This SOLAR PLAN MUST be Possible>>While a high SEER design may be capable of cooling the air more without removing as much latent heat (moisture), what that really means is that it's more critical to properly choose properly sized equipment.
There is a good section about AC and SEER in this - http://consensus.fsu.edu/FBC/ac/Why_People_Florida_May08.ppt
GP -
Re: This SOLAR PLAN MUST be Possible>>GreenerPower wrote: »There is a good section about AC and SEER in this - http://consensus.fsu.edu/FBC/ac/Why_People_Florida_May08.ppt
We decided to run two smaller 2.5 ton variable speed high SEER A/C units rather than one large one. Also at night when the A/C is running, we use fans in our bedrooms to circulate the air.
Splitting the house into two zones conserves power without sacrificing cooling and provides redundancy. In a solar set up like ours, maintaining one temperature setting 24/7 (81 summer) seems to use less power than varying the settings e.g. day vs night.
In addition to Rastra construction, we have retractable shutters on all doors and windows as well as triple pane which significantly reduces how hard the A/C units have to work during the day. These conservation building materials are very important.
Sidebar, after observing power consumption, we disconnected the frequently running heat pumps as they used a large amount of power.Ranch Off Grid System & Custom Home: 2 x pair stacked Schneider XW 5548+ Plus inverters (4), 2 x Schneider MPPT 80-600 Charge Controllers, 2 Xanbus AGS Generator Start and Air Extraction System Controllers, 64 Trojan L16 REB 6v 375 AH Flooded Cel Batteries w/Water Miser Caps, 44 x 185 Sharp Solar Panels, Cummins Onan RS20 KW Propane Water Cooled Genset, ICF Custom House Construction, all appliances, Central A/C, 2 x High Efficiency Variable Speed three ton Central A/C 220v compressors, 2 x Propane furnaces, 2 x Variable Speed Air Handlers, 2 x HD WiFi HVAC Zoned System Controllers -
This looks like an interesting AC setup:
http://www.fafcosolar.com/go-solar/hybrid-solar-air-conditioning/
Uses solar Thermal to help the AC system.
One in action:
http://sensitivedentistry.net/green.html#a18
- 219 Forum & Website
- 127 Solar Forum News and Announcements
- 885 Solar Product Reviews & Opinions
- 649 Solar Water Pumping
- 606 Discussion Forums/Café
- 300 In the Weeds--Member's Choice
