DIY solar car port with certified wind loads
rollandelliott
Solar Expert Posts: 834 ✭✭
I was searching for DIY (do it yourself) solar car port with certified wind loads
and I found this web site:
http://www.premiercarports.com/Solar.html
Does anyone else know of any other companies that create a similar product? From the little research I've done most companies insist on doing a turn key operations with labor and materials and few allow DIY kits.
Seems like for the same price as a unirac system I can have a carport designed and install it myself.
edited to add: they quoted me about $0.80 per watt for the materials ONLY, labor, concrete footers and actual solar rack system to go on top is extra.
Re: DIY solar car port with certified wind loads
http://www.floriansolarproducts.com/waterproof.html
another one, it uses the panesl and gasketing to make a water tight roof ! pretty cool.
3x16 array with 48 panels, ball park price for materials ONLY is $30,000. Seems very high......I could get a stick built tool shed installed for that price.
Maybe hiring a PE isn't that bad of a deal. LOL.
edited to add, exact price was quite a bit less, but still more than the solar panels:
The material cost for a PV-SP14LP with 16 sections (holds 48 Sanyo bifacial panels by others) is $23,523.00. The add-on cost for a Florida PE stamp on our shop drawing is $1,200.00. -
found this wind load company
http://www.windloadcalculations.com/contact-windloadcalculations.asp
anyone use them? or have any other suggestions?
Peace, Rolland
