new guy: Wire gauge
hamr49
Registered Users Posts: 5 ✭
Two questions on wire size.
1. What is the correct Wire gauge to run from the my battery bank, into my
morning star, prostar charge controller? I have 4 150amp batteries.
2. What is the correct wire guage to run from my solar charger to my inverter?
Re: new guy: Wire gaugeTwo questions on wire size.
Well it's ask questions and toss out references time!
First question: four 150 Amp hour batteries configured at what Voltage?
Second question: Distances on wires (array to controller and controller to batteries)?
Third question: How much PV have you got and how is it configured?
Fourth question: Which MS Prostar are you using?
You see it all matters: the Voltages involved, the current expected, and the distances between one point and another.
For a bit of self-help, take a look at this Voltage drop calculator: www.solar-guppy.com/forum/download/voltage_drop_calculator.zip
And another useful reference is this wire gauge table: http://www.powerstream.com/Wire_Size.htm
There will probably be more questions later.
1. Batteries are configured for 12 volts.
2. 25 feet from array to controller. 6 feet from controller to battery bank
3. 2 panels, each panel is 130 watts, 7.56A, 17.2V.
4. Using a ProStar PS 30 PWM CHARGE Controller.
Thanks for help, this is all new to me.Cariboocoot wrote: »Well it's ask questions and toss out references time!
Re: new guy: Wire gauge1. Batteries are configured for 12 volts.
Well I said there'd be more questions.
These batteries: four 150 Amp hour 12 Volt batteries all in parallel? Or are they 6 Volt 150 Amp hours wired for 300 Amp hours @ 12 Volts total?
I see a problem arising with only 260 Watts of panel, which would support 150 Amp hours @ 12 Volts, but certainly not 600 Amp hours @ 12 Volts.
So far it looks like 8 - 10 AWG from panels to controller and 10 - 12 AWG from controller to batteries.
But that is not a precise calculation. -
4, 150Amp hour batteries wired in parallel, 12 volts, 600 amps.
Are you suggesting i cut my battery bank down to 1 or 2 of the 12v, 150Amph
batteries?
ThanksCariboocoot wrote: »Well I said there'd be more questions.
Re: new guy: Wire gauge4, 150Amp hour batteries wired in parallel, 12 volts, 600 amps.
batteries?
Either that or greatly increase your panels. Here's a little piece on deep cycle batteries: http://www.windsun.com/Batteries/Battery_FAQ.htm
There's also some difficulty with keeping current shared properly with four batteries in parallel. Here's a guide about connecting up multiple batteries: http://www.smartgauge.co.uk/batt_con.html
600 Amp hours would want 60 Amps @ 14.4 Volts (assuming FLA's). That would "max out" a big controller like an FM60. It would also need quite a bit of panel: about 1122 Watts worth. Are you sure you need the approximately 3600 Watt hours that battery bank would supply? That's 1.5 times what I run the cabin on. If you do need that much power, you should think about going to a 24 Volt system: it will reduce quite a number of problems with wiring and current handling. But you'd still need a lot more panel. -
Consider a marine battery switch. At least you could keep a pair alternately charged, and then combine them for supply side.Cariboocoot wrote: »Either that or greatly increase your panels. Here's a little piece on deep cycle batteries: http://www.windsun.com/Batteries/Battery_FAQ.htm
