To combine or not to combine, that is the question
sprintman
Registered Users Posts: 16 ✭
The more I try to learn the more confused I feel. I am starting with a small system. Either 3-215 watt 28v panels or 4- 195-200 watt 28v panels. I am thinking I would mount these in series 1) because I can run a lighter wire to the controller and 2) because if I understand correctly a series array will perform better on cloudy or overcast days. I will use an mppt controller. A 12v battery bank. If this goes well down the road I could see doubling the above set up, and going to a 24v battery bank. Do I need a combiner to get started with the first part of the system? As an aside have any of you looked at the combiner you can build.....looks simple and inexpensive, its under projects at Freesunpower.com. Can anyone tell me what size breakers I would use for the above panels. Do you use a combiner when you wire an array in series or is that just for when you wire two or more arrays (that are in series) together. Thanks for your input.
Re: To combine or not to combine, that is the questionThe more I try to learn the more confused I feel. I am starting with a small system. Either 3-215 watt 28v panels or 4- 195-200 watt panels. I am thinking I would mount these in series 1) because I can run a lighter wire to the controller and 2) because if I understand correctly a series array will perform better on cloudy or overcast days. I will use an mppt controller. A 12v battery bank. If this goes well down the road I could see doubling the above set up. Do I need a combiner to get started with the first part of the system? as an aside have any of you looked at the combiner you can build.....look simple and inexpensive its under projects @ freesunpower.com. Can anyone tell me what size breakers I would use for the above panels. Do you use a combiner when you wire and array in series or is that just for when you wire two or more arrays (that are in series) together. Thanks for your input
You don't need a combiner until you have 3 or more strings in parallel.
- 228 Forum & Website
- 618 Discussion Forums/Café
