Shurflo Pump?
Jcrabtree
Registered Users Posts: 24 ✭✭✭
Interested in using this for my off grid cabin - does anyone know which would be best? have 1500gal tank that we use for rainwater harvesting - need decent pressure to the cabin / garden
Re: Shurflo Pump?
So no need for lift, just pressurizing lines? What power do you have available? They make 12 VDC, 24 VDC, and 120 VAC models. The basic 12 Volt is a little over $100. -
Re: Shurflo Pump?
just need pressure - tank is little above the cabin - still debating on 12-24v system -
Re: Shurflo Pump?
Actually, most of the shurflos are good pumps in my experience
I would consider this one for full time:
http://legacy.shurflo.com/pages/RV/rv_categories/potable_water/extreme.html
tony -
Re: Shurflo Pump?
Have one running for 5 years now to a header tank about 10 meters head . Hasn't missed a beat.
I'm on 1 2volts but would definitely go for 24 if starting again.2225 wattts pv . Outback 2kw fxr pure sine inverter . fm80 charge controller . Mate 3. victron battery monitor . 24 volts in 2 volt Shoto lead carbon extreme batterys. off grid holiday home -
Re: Shurflo Pump?
Thanks for the information, last ? How to add it to 24v system if I decide to go that route -
Re: Shurflo Pump?Thanks for the information, last ? How to add it to 24v system if I decide to go that route
24 Volts worth of battery and a charging system to match?
Sorry, but not knowing what you've got now or how much the pump will be used it's hard to be specific. Could you elaborate? -
Re: Shurflo Pump?
nothing yet - still up for debate 12v - 24v system wanted to start off small with rogue charge controller available in June - 4 T105re batteries - panels still up for debate - as for watts/amp - per day still in the works. -
Re: Shurflo Pump?
Just as a sample based on four 225 Amp hour 6 Volt batteries:
112 Amp hours (50% DOD) @ 24 Volts = 2688 Watt hours power potential
22.5 Amps @ 28.8 Volts charging = 648 Watts, less typical 77% derating = 842 Watt array
Quick AC potential estimate: 1684 Watt hours per day.
Could be better, could be worse.
The ol' 12 vs. 24 question still comes down to what you expect to have in sustained loads: 1 kW or less, 12 Volts will do. Over that and 24 becomes attractive.
Were it not for the pumps needed at my locale I would have stuck with 12 Volts - and a much smaller inverter. Skip the electric 'frige too, and I could have used the Morningstar 300. Although that didn't exist at the time. :roll: -
Re: Shurflo Pump?
I highly recommend the variable speed DC pumps for domestic water. They don't cycle on and off when you barely crack open a faucet, just run slower. I'm using the Jabsco version, the only problem that I've found with it is that sometimes the over voltage protection in it will shut it down for 5 or 10 minutes right before my batteries go to float.(any suggestions?) It works well with the demand heater, the heater doesn't shut off if someone opens a faucet somewhere else. -
Re: Shurflo Pump?I highly recommend the variable speed DC pumps for domestic water. They don't cycle on and off when you barely crack open a faucet, just run slower. I'm using the Jabsco version, the only problem that I've found with it is that sometimes the over voltage protection in it will shut it down for 5 or 10 minutes right before my batteries go to float.(any suggestions?) It works well with the demand heater, the heater doesn't shut off if someone opens a faucet somewhere else.
Doesn't like the Absorb Voltage level? How would it respond to a bit of resistance in the line? Just enough to knock out half a Volt or so. Perhaps an appropriate diode? -
Re: Shurflo Pump?
How would I find out more about that? My batteries never go below 25 volts so a volt off wouldn't make much difference. Would a diode cause a decrease in amperage also?Cariboocoot wrote: »Doesn't like the Absorb Voltage level? How would it respond to a bit of resistance in the line? Just enough to knock out half a Volt or so. Perhaps an appropriate diode? -
Re: Shurflo Pump?
Shurflo's are diaphram pumps and works well in my experience. They do put a pulsation into the water however which you'll probably feel/hear throughout your pressurized lines. -
Re: Shurflo Pump?How would I find out more about that? My batteries never go below 25 volts so a volt off wouldn't make much difference. Would a diode cause a decrease in amperage also?
Not an engineer so I'm working from what others have posted.
Putting a diode in line should result in about 0.6 Volt drop, which might be enough to resolve the over-Voltage issue. Don't know the specs on your pump either; but getting the available Voltage to match limit with the pump could be the cause. You could check the Voltage at the pump just before Float and see what it gets up to. Could be the current draw of the causes a momentary Voltage spike when the controller switches from Absorb to Float.
You'd need one rated to handle at least the current of the pump. -
Re: Shurflo Pump?
As Cariboocoot/Marc says, you can get a large diode (mounted to an insulated heat sink) and drop between 0.2 volts to 0.7-1.0 volts or so per diode.
Schottky type diodes are closer to 0.2 volt drop. And "regular" power diodes are closer to 0.7 to 1.0 volt drop.
Remember, if you run, for example 5 amps through a 1 volt drop diode, you will have to heat sink it:- Power = Current * Voltage = 5 amps * 1.0 volt drop = 5 watts of heat
Re: Shurflo Pump?Actually, most of the shurflos are good pumps in my experience
tony
I agree icarus. My brother uses shurflo pumps on a regular basis. He hasn't used one that he hasn't liked. I don't really know much about them personally. I have never used them. -
Re: Shurflo Pump?
I used a 12 volt in my rv prior to the cabin, and without a hitch. The diaphragm nature does create a pulsation in the water lines, but it is no biggie. They do have a pressure tank that is supposed to eliminate the pulse and the turn on-turn off cycling when someone opens a faucet. I plan on putting a 120 volt in the cabin and have faith it will work as well as the 12 volt did.
