Where to buy MC4 Terminal's
gtxkid
Solar Expert Posts: 34 ✭✭
Re: Where to buy MC4 Terminal's
I'm sure Wind&Sun sells the cables. If you need just the connectors and the parts to make cables, Newark sells them.
http://www.newark.com/jsp/level5/module.jsp?moduleId=en_US/176240.xml -
Re: Where to buy MC4 Terminal'sIs there a place to get them at a good price.
I need 12 Male and 12 Female.
When I was looking around last month I found that it's generally cheaper to buy a cable that is long enough for your plans and cut it in 1/2.
That way you get the MC4 terminals that are ALREADY properly crimped onto a cable that is UL rated for outdoor use.
Just buy 12 Male to female cables and you're good to go.
P.s. the prices on Wind-sun are about as good as anywhere else I've found. Might find them cheaper on eBay, but then you're gambling on unknown Chinese crap. -
I've gotten some from http://duncansolar.storesecured.com/items/connectors/multi-contact/list.htm. They have the best price I've found for what appear to be genuine MC connectors. (I don't believe NAWS has the bare connectors.)
