adding a 3rd panel
bobdog
Solar Expert Posts: 192 ✭✭
I have 2 KC130s in parallel and am going to add another KD 135 to the mix. Since I have a PWM CC and everything is already wired to the CC from the panels, running in series and using a MPPT CC is not an option right now. So, 2 questions.
1) Do I need a bypass diode in between each panel?
2) I plan on putting an inline fuse between each panel. Is that appropriate to do? The fuses will be 10 amp in size.
Thanks.
Thanks.
Re: adding a 3rd panel
You do not need to add any diodes.
Yes, you now need to add a fuse to each panel whose value based on the data sheet (usually called the "Series Fuse").
And the parallel Imp/Isc of the array should not exceed the specifications of the PWM controller.
max fuse size as per specs here = 15A
http://lib.store.yahoo.net/lib/wind-sun/KD135GX-LPU.pdf
Eric
Thanks folks. That's what I needed confirmed.
