Bragging About My Solar Harvest
Derik
Derik Solar Expert Posts: 82 ✭✭✭✭
Most of my posts here are about how some of the formulas for solar sizing don't work in the southern states with high altitude and no shade. True to form here is an example. On Friday my less than 2,000 watt system made about 3.5 kw of power due to a front coming in and low use on my part. Saturday was cloudy all day with sleet, rain and snow, the Mate showed I made under 2.5 KW. Sunday rolls around and it's sunny when I wake up and about one inch of snow on the ground. It stayed sunny all day.
I made a whopping 12.5 KW! with under 2,000 watts of solar panels. I did three loads of laundery vacumed, ran the microwave and had the tv on most of the day. My guess is I used about 4.5 KWH and the other 8 was used to fill the battery bank of 12 trojan L-16' B. I did a hydrometer reading on Friday and had 1.250 and conserved on Saturday so I never went below 70-80%.
Anyway happy to be off grid and having a good harvest!
  • solarix
    Re: Bragging About My Solar Harvest
    Would you please correct your errors between kwh which is energy and kw which is power so we know what you are talking about?
  • Derik
    KWH is what is used and KW is what is made that's the way it was explained to me.
    The words Used and Made should mean something to you!
    Envy raises it's ugly head in many circles.. if I would have listed my system details you would have probably said " you need more solar" or You can't charge your panels without a generator..
    Keep it positive! I am making tons of power and I am happy about it!!!
  • mr.radon
    mr.radon Solar Expert Posts: 158 ✭✭✭✭✭
    Sorry:
    KW = the ability to make power (is a unit of power)
    KWH is the power actually made or used. (is a unit of energy)
    power * time = energy
    So when reporting keep the units consistent. ;)
    KW is used to describe the solar panels or engine output.
    KWH is used to describe the energy made/used or stored by the batteries.
  • icarus
    Well, it was explained to you incorrectly.
    A kilowatt is 1000 watts. A kilowatt HOUR the consumption (or production) of 1000 watts for one hour. So, while a 1000 watt generator might produce 1000 watts, if you plug in 10, 100 watt light bulbs that would be a 1 kw load, burn them for 1 hour and you will use 1 kilowatt hour.
    So your 2000 watts of panel will never, under any circumstances produce 12 kw, but it might produce 12 kwh over a 6 hour period. The amount of power used or produced is only relevant with a time component, hence kilowatt HOUR.
    I might add, as a moderator, that you should consider your tone a bit. People here are more than willing to share their knowledge with everyone, and most strive for accuracy. And by the way,, you don't "charge panels" you either feed loads (or grid) or you charge batteries.
    You should also realize that PV panels will often produce more than rated output in cold conditions, and output is often further increased with reflection off of snow. Edge of cloud events can increase this even further.
    As for the size and capacity of an off grid system, one ideally designs for average rather than best or worse case situations. The general rule of thumb that I use is the 50%X4 rule. That is take the name plate rating of the PV (in your case 2000) divide that in half to account for all cumulative system loses, then multiply that number by 4 to represent the average number of hours of good sun one might reasonably expect on a daily basis over the course of the year.
    2000/2=1000X4=4 kwh/day.
    On might on a perfect day double or triple that, but one certainly can't count on that as an average. Some local adjustment might be in order, but seldom more than ~ 6 hours over the course of the year. As an FYI, we live off grid with ~ 400 watts of PV. On average, we use ~600 watthours/day. On an ideal day we can generate as much as 1.5- 2 kwh. Over the course of the year, cold weather, cloudy days, it averages out to just about my 400/2=200X4=800 watthours/day.
  • Derik
    Most report here are problems I was reporting a good harvest! My point is that solar is sun and I have much more than you or my northern brothern.
    ICARUS Your formula would have me stuck with much more solar than I would ever use or need. Maybe 3 X. This was a good power day only because we had two days of clouds and my system made up for it.
    WE GET 350 Days of Sun a year!!! Two days of clouds just let's my system flex it's muscle and make the energy I normally don't need.
    The title was "Bragging about my solar harvest"
    I never said " I charged the panels" I have had two solar experiences one a cabin and one a home I installed my own systems under the direction of a Solar Guru and have had none of the experiences you have had with my systems. I might get KWH and KW confused but I know the basics.
    Here is my corrected version to make an accurate account of what I was trying to say. I revised my post to read KWH on all accounts.
    Most of my posts here are about how some of the formulas for solar sizing don't work in the southern states with high altitude and no shade. True to form here is an example. On Friday my less than 2,000 watt system made about 3.5 kwh of power due to a front coming in and low use on my part. Saturday was cloudy all day with sleet, rain and snow, the Mate showed I made under 2.5 KWh. Sunday rolls around and it's sunny when I wake up and about one inch of snow on the ground. It stayed sunny all day.
    I made a whopping 12.5 KWh! with under 2,000 watts of solar panels. I did three loads of laundery vacumed, ran the microwave and had the tv on most of the day. My guess is I used about 4.5 KWH and the other 8 was used to fill the battery bank of 12 trojan L-16' B. I did a hydrometer reading on Friday and had 1.250 and conserved on Saturday so I never went below 70-80%.
  • icarus
    Like I said, adjustments for local variance is always in order. The fact that you get 350 days of good sun is certainly an adjustment factor to consider. As with all rules of thumb, that is what they are,, rules of thumb.
    Quite frankly, on an annual basis your harvest may not be any better than an northern neighbour. Remember, in the far north, folks can get more than 18 hours of day light, and depending on local weather variance, can more than make up for 6 hours in the winter. Also, in the winter, shorter days tend to come with colder temps increasing PV output, as well as an increase due to reflection off of snow and ice. My average works out just about the same winter and summer, as some of my summer harvest gets lost due to some shading issues, while my winter harvest is better due to the above factors.
    I am happy for your harvest.
    Icarus
    PS
    From you post #3,, just a bit nit-picky tonight.
  • Peter_V
    Peter_V Solar Expert Posts: 226 ✭✭✭
    Clear skies and cold weather are awesome!
    Yesterday My 3.45 kw (DC) array made 26.1 kwh!
    Really impressive because my inverters limit my max AC output to 2.98 kw.
    The trackers do help a bit ;)
  • russ
    russ Solar Expert Posts: 593 ✭✭
    I have yet to read any article that really tells what panel output can be expected anyway.
    The test conditions are using 1000 watts/m2 - which virtually never happens at
    The second set of conditions shown on a panel rating are using 800 watts/m2
    In the winter few locations (except sunny Arizona and southern CA) see the 800 figure.
    Here we are only now getting close. Two days with a 5 minute reading over 800 watts/m2 last month and a month average of 2.97 kW/m2/day. It seems like about 85% of the daily kW received are in the window where the panels can utilize them).
    At my location - NASA shows an annual average insolation of 5,07 watts/m2.
    In June, which seems to be our best month, the average daily insolation (last year) was 8.38 kW/m2/day. I record the hourly average insolation (DNR), daily total insolation and UV readings plus high momentary insolation for the day.
    If a panel is 10% efficient (and that has to be 10% of available sun otherwise it makes no sense) and you have a 100 watt panel -
    On a day with an insolation total of 2.97 kW/m2/day and considering 85% of that usable there would be 2.52 kW/m2/day of useful available sun. 10% of would be 252 watts.
    Whether the panel is 100 watts or 300 watts you can't get more than that from the math. The 100 or 300 watts would be a maximum only I guess.
    This does not seem to tally well with what people report and too many people tell a similar story so it is not possible to doubt them.
    Trying to figure out the 'rest of the story'.
    Russ
  • mr.radon
    Funny, 4 months after flipping the switch , I've made within 2% of what PV Watts predicted! As far as I'm concerned that data base/tool is nuts on.
  • SteveK
    SteveK Solar Expert Posts: 387 ✭✭
    And it is good when you can load shift during peak hours like you did. It saves 10-20% loss while charging the batteries. But it is a loss that does exist and needs to be included like they do here.
  • russ
    mr.radon wrote: »
    I am trying to think of a real number rather than an average of averages over months or years.
    I never said PV Watts was not correct.
  • solarix
    Derik:
    My bad for giving you a technical nerd response.
    I applaud you for your power production. Isn't it great!
    We need to celebrate this stuff more. Throw a party - have a cold one on me!
  • Peter_V
    russ wrote: »
    -snip-
    Russ
    From what I gather the 1,000 watts/m2 is what they use for STC ratings.
    It's also important to note that panel output changes depending on panel temperature. Normally panels end up getting hotter than the temperature used for STC ratings so they produce less power than STC (hence the PTC rating system)
    However, when it's cold out a panel can produce MORE than it's rated output. I have seen that around here on days when the air temps are in the 30s to low 40s.
    I have seen 180 watt panels produce almost 200 watts.
    I haven't taken measurements so I don't know if we are getting more or less than 1,000 watts/m2.
    I can tell you that I live way south in AZ (6 miles from Mexico) and that we are at a fairly high altitude, around 4600 ft.
  • russ
    From my Davis weather station which seems to come close to the NASA 10 year averages - we saw 1000 watts/m2 for one hour average last May.
    The daily average for the month was 6.370 kW/m2/day.
    Today it was 2.824 kW/m2 for the day. The high reading for an hour was 544 watts/m2.
    The panel output would have to be different.
    Understand the temp affect no problem - straight math and simple at that.
  • Derik
    Thanks Solarix I must admit I was feeling a little beat up for just reporting a good days harvest.
    I will have a cold one on you.
    Icarus I am happy you are happy I had a good harvest, but please read my post before you attack. I was quoting what others here might say not saying I charged my solar panels, you took what I said out of context.
    I can think of many reasons that a guy in the north can't produce near as much solar as a guy in the south but to keep on the positive here I'll just keep on reporting what I am making!
    My system produces much more than what it was suppose to produce and I see few losses! So I am very happy living off grid!
  • hillbilly
    hillbilly Solar Expert Posts: 334 ✭✭
    Congrats on your system performance Derik! We often get some really good production on sunny winter days too; Sun+ Snow+ Cold= lots of PV generation. I also wanted to reiterate that there are indeed some very knowledgeable and very helpful folks here, some here are even BOTH at the same time :-) While it's easy to find flaws in any rule of thumb, bear in mind that most of the suggestions you'll find here are based on pretty well informed people. There's no way that you or anyone else should ever trust 100% what you read on the net, but all in all I've found that I always leave here having learned something new and/or having some new ideas on how to optimize life off the grid. In short, stick around, take what you see with a grain of salt, but don't discount the ideas and suggestions put forth ... I can guarantee you'll end up far more informed and equipped to deal with any issues if/when they do pop up in your system.
    Cheers.
