Ventilation
(1) I need to install my batteries in my two car garage. Is this to confined a space for the lead-acid type battery?
(2) Which battery and dealer would you recommend?
Thank you
Thank you
Re: Ventilation
There are several things with Lead Acid Batteries to watch out for:- Hydrogen gas during charging (gas rises, so vent hood/box for batteries with good ventilation, may not be needed if there is no sealed roofing system where hydrogen can collect--Some people use a small computer fan when the batteries are charging)
- Hydrogen gas + acid mist--Keep "expensive" stuff at least a couple fee from un-contained batteries (box?)
- Acid Spills--Will ruin whatever the batteries are sitting on (again, box to hold acid).
- Keep top of batteries covered to prevent tools and small hands from getting to the wiring (1,000's of amps available in dead short--in some ways more dangerous than 120/240 VAC leaving house wiring exposed). (box?)
- If you have very cold weather (way below 0F) and run the batteries below 50% state of charge--they can freeze and split the cases (box, insulated box?).
However, AGM's as they reach end of life, or in some overcharging situations can vent hydrogen gas and acid mist--so it is still recommended that you treat them with respect.
- 230 Forum & Website
