solar panel out puts
conntaxman
Solar Expert Posts: 125 ✭✭✭✭✭
Im just finishing 1 small 36 cell panel 3x6 poly .5volt 3.6 amp. My question is after i make a few of these sizes[ i have alot of glass that size] I plan to run a bus bar to connect the panels to. I know that some will put out different voltages and amps. In between Each panel and buss bar I will be putting a blocking diode. Then go to a controller MPPT or a PWM, I don't know which one yet. I hope to end up with about 1000 system atleast. Useing 12volt batteries. Guess my question is. will all the panels be putting voltage or amps into the batteries if they are calling for it?Like if one panel is putting out 18 vdc and another is putting out 15 vdc, will it Draw amps from the 15 volt panel and 18.
tks
in this exp. each panel will be tied in to the buss bar.
John
tks
John
Re: solar panel out puts
If you are using a PWM controller or attaching the panels (through a diode) directly to the battery bank, they will each supply current based on their I*V Curve...
The 18 Volt panel charging a battery bank to 14.4 volts will be near maximum current.
The 15 volt panel as it gets warmed up, will probably not supply its maximum current to the battery bank once the battery is much over 13 volts or so (as solar panels heat up, their Vmp drops--that is why a "12 volt" panel has Vmp=~17.6 volt or so and to support ~1-2 volts of controller/wiring voltage drops too).
B.B. thanks for the reply,thats what i though, that each panel would produce something. The way made the panels I will be able to add more cells in series to bump up the voltage for each and not waste any cells. Like add just 4 more cells to get 2 more volts to to that one panel.
I don't know what type of controler to pick up yet.I know that I want to ATleast build up to 500watts ,and then more.
Tks
John -
BB. my other question is ,Will the 15 volt panel be supplying ANY amps to the buss bar,like i said, I will be hooking all these panels to a buss bar.I know if the battery is above the voltage of the panel that panel will do nothing in supplying voltage,so I guess it will not supply any amps either.Where voltage carries the amps.
Johnny
.....PS....
Which one of these would be the better of the two.I think the 1st one is because it is a mppt
Wellsee charge controler Ebay Item number: 280608149734 and cost $70.00
ws-c2430 20A
p fangpusun PR3030 Ebya ITEM NUMBER IS 110625631643 and cost $69.00 -
Re: solar panel out putsconntaxman wrote: »BB. my other question is ,Will the 15 volt panel be supplying ANY amps to the buss bar,like i said, I will be hooking all these panels to a buss bar.I know if the battery is above the voltage of the panel that panel will do nothing in supplying voltage,so I guess it will not supply any amps either.Where voltage carries the amps.
Yep--The old water analogy is helpful... Water needs to flow down hill... Electricity needs to push current from a high(er) voltage to a low(er) voltage point. If the voltages are equal--no current flow.
So far, I have not heard of a cheap/successful MPPT type charge controller... And if you are planning on Vmp~17.5 volts (not connecting in series for 2x17.5=35volts for example)--I would choose the PWM as it is probably more likely to work correctly.Which one of these would be the better of the two.I think the 1st one is because it is a mppt
Wellsee charge controller Ebay Item number: 280608149734 and cost $70.00
ws-c2430 20A
Realize, that you are paying about 1/3rd to 1/4th the going rate for a low end MPPT charge controller. There is a lot that can "go wrong" with MPPT and you don't want to have to hunt down issues and figure out what is going wrong (controller or elsewhere).
And if you are Vmp=18 volts + 15 volts or so, an MPPT is not going to do anything better for you (and may be worse) when compared to a simple PWM type charge controller.
BB. Thank you very much for the info about the controllers. It was /is very helpfull.So now I will get the PWM. Later if I put them series then I'll think about the other .But it is very nice to get info from you.
I still have a few more of these 60 watt panels to make and then I will try them on the office with a computer which draws 1 amp per hr with monitor. I bought a watt meter that everyone was talking about on the site,It is very help full and Fun to use/see.
Have a nice day/night.
tks
Johnny -
Remember that 1 amp at 120 VAC is 10 amp draw at 12 VDC (unless that is a very low power monitor running off 12 VDC)...
oh, didn't know that 1 amp 120vac = 10 amps dc. Thats a lot. I'll have to remember that.But i was amazed when I saw only .90 amps draw for the computer and monitor, and that is while it was working, like surfing the net.It's amd.
tks
Johnny -
I am guessing the amps... Remember Power = Volts * Amps- Power = 1 amp * 120 VAC = 120 Watts
- Power = 10 amps * 12 VDC = 120 Watts
For larger off-grid Solar PV systems, there are 24 and 48 VDC systems too:- Power = 5 amps * 24 VDC = 120 Watts
- Power = 2.5 amps * 48 VDC = 120 Watts
- Power = Volts * Amps * Power Factor
For CFL bulbs, many electronics, electric motors and such, PF typically is ~0.6 to ~0.7 -- So the Amps measured * Volts measured do not always equal power (Watts).
AC quickly becomes not like DC when measuring power... There is another unit called VA (Volt Amps) to represent how much current and voltage an AC device is using.
And VA*PF = Watts (Power)
hello BB. What would you think of this solar controller for a starter.
http://sunelec.com/index.php?main_page=product_info&cPath=22&products_id=39
Morningstar Solar Charge Controller 45A TriStar TS-45
$159.12
Ive been reading a few days and looking at many.This morn/ts45. seems that it would do good .I would like a dig/meter on it ,but I could buy an amp and volt meter and hook those up myself, I want to build up to atleast 1,000 watts of panels. I think this will only take up to about 500 watts, not sure on that one. But another thing about it is that it has Knock out steel plugs and takes a large wire size. I think it is made in the USA also. So what would you say, good/s and bad/s.
tks
John
Going to go work on more cells.[tab em] also metal frams and uv epoxy /vacum out air also. -
That is a fine PWM controller from what I know of it (my system is Grid Tied--so I have not used any solar charge controllers--just my reading/searching here).conntaxman wrote: »
One really neat thing about all of the Morning Star TS series charge controllers--They have a pair of remote battery voltage sense leads. This allows the controller to more accurately measure battery voltage without the voltage drop of the controller to battery bank cables. You can use longer wire and/or smaller gauge (still needs to be thick enough for rated current) and still have very accurate battery voltage control. Will generally support faster charging of the battery bank.
For large computer systems where we have to hold tight voltages for the 5 volts, 3.3 volts, etc... We always had remote voltage sense leads.
Also, our host NAWS sells the Morning Star line too.
If you can justify it--Always recommend the remote battery temperature sensor option too for charge controllers that support RBTS.Ive been reading a few days and looking at many.This morn/ts45. seems that it would do good. I would like a dig/meter on it, but I could buy an amp and volt meter and hook those up myself, I want to build up to at least 1,000 watts of panels. I think this will only take up to about 500 watts, not sure on that one. But another thing about it is that it has Knock out steel plugs and takes a large wire size. I think it is made in the USA also. So what would you say, good/s and bad/s.
Are you going with a 12 volt battery bank? And the cable run from the array to the charge controller+battery bank not too long (you looked at wire gauge/lenght vs voltage drop)?.
A Battery Monitor is probably a better investment than the digital meter for the charge controller.
One short warning about DIY panels... They tend not to last more than a few months out in the weather (thermal cycling, moisture, flexing from wind, etc.). Don't spend a whole bunch of money on support equipment until you are satisfied that your panels will last (or you have the capital for commercial solar panels). And if they are made with wood/plastic structural components--don't mount them where, if there was a fire, it would be a problem.
