RV Solar System / Charge Controller
tr0y
Solar Expert Posts: 99 ✭✭✭
Hi All -
With your help I have now been living off the grid for over a year in my solar powered house, now it it time to outfit the RV.
My RV is 12v based, interior lights, water pumps, audio and video etc, I also have a 120v system for the micro, fridge, and some outlets for other 120v stuff.
I currently have a Xantrex / Trace DR1512 inverter charger, four 400 AH 6v AGM lifeline batteries, and I charge from either shore power or a quiet Honda 2000 generator. I have come into four 100 watt, 12v panels that I am going to mount on the roof.
My question is what do you all think would be the best way to wire panels and what to do about a charge controller ?
Should I wire the panels as a 12v system get a cheap charge controller and call it a day ? or do I wire them up as 48v get a nice MPPT charge controller and do it the same way my home is wired up ?
What route would be best ? and if it is going with a nice MPPT charge controller, do you think the cost would be worth it vs less efficiency ? Am I going about this all wrong ?
We use the trailer a couple times a month for a couple of days at a time, not sure that the solar piece is really necessary but the panels were free.
Re: RV Solar System / Charge Controller
Part of it depends on the actual Vmp of the "12 volt panels"... If they are between ~17-20w volts Vmp--then you can use either a PWM or MPPT type charge controller... If they are below or above that voltage range, then you probably want an MPPT.
Roughly:- 400 watts / 17.6 volts = 22.9 amps
At 400 amps and a short run from the panels to the charge controller/battery bank--either PWM or MPPT should work fine.
If you RV in significantly hot or cold (below freezing weather)--The wider voltage range of an MPPT controller with two (or more depending on controller and panel Vmp) panels in series can be nice.
You could also look at a (cheaper PWM controller without display) and put some of the savings towards a battery monitor (really nice for AGM batteries where you cannot measure specific gravity).
Re: RV Solar System / Charge Controller.. or do I wire them up as 48v get a nice MPPT charge controller ...
That's how I would do it. -
Thanks guys it sounds like the MPPT route is the way to go. The panels 17.x Vmp a Keocerya of some sort.
I think I have a line on a pre-owned Outback MX60 for 200.00ish so I think I will do that.
Next Question - I also think I need to put some better / bigger fuses in the positive cables, what would you suggest for RV use building a box with breakers just doesn't fit the space.
Thanks Happy Christmas ! -
I'm using ANL fuses that are normally used for stereo installs. Most fuse holders will handle up to a 0 awg wire. -
These are great for small spaces. From Blue Sea. They attach right to the battery terminal. -
Thanks that little Stud fuse is cool. Would be perfect.
- 230 Forum & Website
