Looking for Wind Turbine Recommendations in Greece
hi
so, for you ,what you kind of wind turbine will be good in greek region?
also to have suport from the company
until now I have conect with sky stream
thanks
thanks
Re: Looking for Wind Turbine Recommendations in Greece
I have moved your question to its own thread.
You could contact 'rogeriko' on this forum: http://www.navitron.org.uk/forum, he installs a bunch of wind turbines and off-grid systems on the islands. -
Have you tried Bornay or Sonkyo Energy? They are located in Spain.
Rick -
Hi there .... In Alberta we are using a few options ... to me it comes down to your wind speed and where do you want to put it .... also how big .. which also relates to the location . High wind areas gust up to 120 miles per hour ... look at a ropatec
solid and made in Italy . If your looking at gust up to 70 miles per hour look at a Horizontal and there are a few on the market as long as you put in the right safety equipment ... mporta@pcequip.ca
